Samsung 860 DCT 1.9TB SATA 6Gb/s 2.5" SSD Hard Drive
Quicklinx: DWZCWS00 Mfr#: MZ-76E1T9E
Form Factor: 2.5"
Capacity: 1.9TB
Interface: Serial ATA-600
Type: Internal hard drive
Hurry, only 1 left in stock!
£274.45 ex VAT
£329.34 inc VAT
Samsung's 860DCT SSDs deliver optimized performance and value for read-intensive applications like servers and data centers. They feature Samsung's proprietary V-NAND technology and are built from Samsung components for a high-density, reliable enterprise storage solution with low power consumption, strong data security and proactive monitoring.
  • V-NAND technology
    Samsung's V-NAND flash memory helps overcome the limitations of conventional planar NAND architecture. It stacks 48 cell layers vertically over one another rather than trying to fit itself onto a fixed horizontal space, in order to provide high density and performance with a small footprint.
  • Optimized performance and value
    Built to handle the heavier workloads of data center usage, the 860DCT delivers a high level of sustained performance at a great value for your business.
  • Outstanding reliability
    The 860DCT is optimized for server and data center environments by offering reinforced endurance and low power consumption.
  • Data protection for peace of mind
    Secure data without performance degradation thanks to AES 256-bit encryption.
  • Efficient power management
    Thanks to low power consumption, you can enhance efficiency for operations and maintenance.
Samsung 860 DCT MZ-76E1T9E - solid state drive - 1.9 TB - SATA 6Gb/s
Solid state drive - internal - Auto Garbage Collection Algorithm, Samsung MJX Controller
1.9 TB
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
3D triple-level cell (TLC)
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Auto Garbage Collection Algorithm, Samsung MJX Controller, S.M.A.R.T.
69.85 mm x 100 mm x 6.8 mm
60 g
5-year warranty
1.9 TB
256-bit AES
2.5"
SATA 6Gb/s
69.85 mm
100 mm
6.8 mm
60 g
Performance
SSD Endurance
698 TB
Data Transfer Rate Details
Serial ATA: 600 MB/s
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
550 MBps (read) / 520 MBps (write)
Maximum 4KB Random Write
19000 IOPS
Maximum 4KB Random Read
98000 IOPS
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
SATA 6 Gb/s
Compatible Bay
2.5"
Power Consumption
2.95 Watt (write) , 1.05 Watt (idle max)
Software Included
Samsung SSD Magician DC
WWN
Limited warranty - 5 years
70 °C
Shock Tolerance (operating)
1500 g @ 0.5 ms half-sine
Form Factor: 2.5"
Capacity: 1.9TB
Brand: Samsung
Price Range Ex VAT: 150 - 300
