Upgrade virtually every aspect of your computer's performance with Samsung's 850 EVO, designed with state-of-the-art SSD advancements including 3D V-NAND technology.
Samsung's 3D V-NAND flash memory architecture breaks through density limitations, performance and endurance of today's conventional planar NAND architecture. Samsung 3D V-NAND stacks 32 cell layers vertically resulting in higher density and better performance utilizing a smaller footprint. -
Optimize daily computing with TurboWrite technology for unrivaled read/write speeds
Achieve the ultimate read/write performance to maximize your everyday computing experience with Samsung's TurboWrite technology.
- Samsung 850 EVO Basic MZ-75E2T0 - solid state drive - 2 TB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 2 TB
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 2 GB
- Hardware Full Disk Encryption (FDE), TRIM support, DevSleep mode, Microsoft eDrive compatible, 3D V-NAND Technology, Auto Garbage Collection Algorithm, Dynamic Thermal Guard protection, Worldwide Name (WWN), RAPID mode support, TurboWrite Technology, Samsung MHX Controller, Low Power DDR3 SDRAM Cache, S.M.A.R.T., 256-bit AES, IEEE 1667
- 69.85 mm x 100 mm x 6.8 mm
- 66 g
- 5-year warranty
- Capacity
- 2 TB
- 256-bit AES
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 2 GB
- 69.85 mm
- 100 mm
- 6.8 mm
- 66 g
Performance
- SSD Endurance
- 150 TB
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 540 MBps (read) / 520 MBps (write)
- 4KB Random Read
- 98000 IOPS
- Maximum 4KB Random Write
- 90000 IOPS
Reliability
- MTBF
- 1,500,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5"
- Power Consumption
- 4.7 Watt (average) , 2 mW (sleep) , 7.2 Watt (maximum) , 60 mW (idle)
- Software Included
- Samsung Magician Software
- Limited warranty - 5 years
- 0 °C
- 70 °C
- 5 - 95% (non-condensing)
- Shock Tolerance (non-operating)
- 1500 g @ 0.5 ms half-sine pulse
