Dynamic Crystal Colour on this Samsung DU8000 TV brings rich spectrum of hues and tones to your screen – over one billion shades in fact. That's 64 times more than conventional 4K TVs. You'll love how good documentaries and movies look. Sound is more realistic too thanks to Object Tracking Sound Lite – the TV speakers follow the on-screen action. The Crystal Processor 4K is the brain of the TV. It's hard at work in the background boosting the picture and sound of everything you watch in real-time.
- Samsung UE75DU8000K DU8000 Series - 75" LED-backlit LCD TV - Crystal UHD - 4K
- Product Type
- LED-backlit LCD TV - Crystal UHD - Smart TV
- Diagonal Class
- 75"
- Black
- Platform
- Tizen OS
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- HDR Format
- HDR10+
- Frame Rate & Enhancement Technology
- 50 Hz Refresh Rate, Motion Xcelerator
- Video Interface
- HDMI
- HDMI Ports Qty
- 3 ports
- Connectivity
- Wi-Fi, LAN, Bluetooth
- LCD Backlight Technology
- LED backlight UHD dimming
- Image Aspect Ratio
- 16:9
- TV Tuner
- 1x analogue, 1x digital
- Digital TV Tuner
- DVB-C, DVB-S2, DVB-T2
- Internet Streaming Services
- Samsung TV PLUS, HbbTV 2.0.3
- Picture Enhancements
- Mega Contrast, contrast enhancer, 4K Upscaling, Dynamic Crystal Color
- Speaker System
- 2 channel
- Platform
- SmartThings
- Intelligent Assistant
- Google Assistant, Bixby, Alexa (not available for some languages and countries)
- USB
- 2 ports
- Included Accessories
- Samsung TM2360E remote control, Samsung TM1240A remote control
- Voltage
- AC 220-240 V (50/60 Hz)
- Energy Class
- Class G
- 137 Watt
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 190 kWh
- Dimensions (WxDxH) - without stand
- 167.67 cm x 2.66 cm x 96.03 cm
- 31.4 kg
- 2-year warranty
- Product Type
- Energy Class
- Class G
- Energy Class (HDR)
- Class G
- Power Consumption (Max)
- 255 Watt
- 137 Watt
- Power Consumption SDR (On mode)
- 137 kWh/1000h
- Power Consumption HDR (On mode)
- 227 kWh/1000h
- 190 kWh
- Diagonal Class
- 75"
- Series
- DU8000 Series
- Model Year
- 2024
- Platform
- Tizen OS
- HDR Capable
- HDR Format
- HDR10+
- Video Processor
- Crystal 4K
- TV Tuner
- TV Tuner Presence
- Sensors
- Eco Sensor
- Video Interface
- HDMI
- HDMI Ports Qty
- 3 ports
- Modes
- Auto Game Mode, Auto Low Latency Mode (ALLM), Filmmaker Mode, HGIG Mode, AI Energy Mode
- Design
- 3 Bezel-less Design, Slim look, AirSlim design
- Dimensions
- Without stand
- 167.67 cm
- 2.66 cm
- 96.03 cm
- 31.4 kg
- Enclosure Colour
- Black
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- Display Menu Language
- Multilingual
- Embeded POP, Wireless TV On, Apple AirPlay support, Samsung Health, Gaming Hub, Nifty Gateway, Workspace, USB webcam support, Samsung Daily+, Samsung Knox Security
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Stand Colour
- Black
- Stand Features
- Float Lift
- Flat Panel Mount Interface
- 400 x 400 mm
- VESA Compatibility
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
- Digital TV Service
- HbbTV
Video Features
- Teletext
- Electronic Programme Guide
- Digital EPG
Media Player
- USB Port
- USB Ports Qty
- 2
Remote Control
- Remote control
- Remote Control Model
- Samsung TM2360E
- Additional remote control included, SolarCell remote
Audio System
- Speaker System
- 2 channel
- Output Power / Total
- 20 Watt
- Audio Return Channel (ARC), Enhanced Audio Return Channel (eARC), Audio Pre-selection Descriptor, Adaptive Sound, Q-Symphony, Object Tracking Sound Lite
Network & Internet Multimedia
- Functionality
- WEB browsing, Internet video playback
- Connectivity
- LAN Protocol
- Ethernet
- Wi-Fi Protocol
- 802.11ac
- Bluetooth Version
- Bluetooth 5.2
- Connect & Share
- Screen Mirroring, Smart Hub, Sound Mirroring, IP Control, Tap View, Multi View
- Supported Consumer Electronics Control (CEC)
- Anynet Plus
- Connector Type
- 3 x HDMI , 2 x USB , LAN , Digital audio output (optical)
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Platform
- SmartThings
- Communications Technology
- Thread, Zigbee
- Google Assistant, Bixby, Alexa built-in (not available for some languages and countries)
- Samsung TM1240A remote control
- CEC, HGiG
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Auto On/Off
- Limited warranty - 2 years
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 167.67 cm x 2.66 cm x 96.03 cm x 31.4 kg , Panel with stand - 167.67 cm x 34.04 cm x 100.55 cm x 32 kg , Stand - 126.96 cm x 34.04 cm , Stand (minimum) - 104.98 cm x 34.04 cm
- Width (Shipping)
- 183.4 cm
- Depth (Shipping)
- 19 cm
- Height (Shipping)
- 111 cm
- Weight (Shipping)
- 42.3 kg
