Samsung 65" The Frame (2023) QLED 4K Art Mode Smart TV
Quicklinx: H7HSWS00 Mfr#: QE65LS03BGUXXU
Make your own TV
The Frame is a stunningly slim TV that you’ll want to watch even when it’s off. More than just a TV – it’s a glare-free canvas that can be endlessly transformed to showcase the things you love in your home, inspiring you to reinvent your everyday space.
Experience glare-free picture viewing
Matte Display
Tired of seeing distracting glare on your TV screen? The Frame's ground-breaking Matte Display overcomes this problem as it absorbs reflections - so even in bright light you'll have the best possible viewing experience. It also helps your TV look just like a picture frame, so you can enjoy beautiful artwork on a glare-free canvas.
Designed to look just like a picture frame
Modern Frame Design
The Frame is a stunningly slim TV that you'll want to watch even when it's off. This elegantly minimal TV with tidy cables even hangs just like a picture frame, near flush to the wall, so it'll blend beautifully with your home.
TV when it’s on, Art when it’s off
Art Mode
Instead of turning into a black screen, The Frame transforms into a showcase of beautiful artwork and photography when it's turned off, allowing the TV to become part of your décor. Enjoy your favourite pieces for as long and as often as you like.
  • Experience glare-free picture viewing
  • Modern frame design
  • TV when it's on, Art when it's off
    Instead of turning into a black screen, The Frame transforms into a showcase of beautiful artwork and photography when it's turned off, allowing the TV to become part of your décor. Enjoy your favorite pieces for as long and as often as you like with no screen burn worries - guaranteed.
  • Senses your presence
    When you're in the room, the Motion Sensor detects your presence and automatically turns the TV to Art mode, So you can enjoy art while you're there. When you leave, it turns off into standby mode to save energy.
  • The ideal way to appreciate art, in any light
    The Brightness Sensor detects ambient light and automatically adjusts the screen's brightness and color tone to perfectly match the art piece on display.
  • Naturally bright and colorful picture
    See everything you watch come to life with greater detail and realism. Samsung's Quantum Dot powered TVs transform light into lifelike and accurate color - validated by Pantone. The result? A naturally bright and colorful picture in over a billion cinematic colors.
  • An intelligent AI processor that automatically optimizes the picture and sound
    Think of the processor as the brain of the TV. The smarter the processor, the better your experience will be - and this processor introduces AI to optimize your content. It adjusts the brightness and upscales the resolution of what you're watching to 4K, even if it wasn't filmed that way.
  • Easy on the eyes
    Brilliant viewing, no matter the time of day. Sit back, as The Frame automatically readjusts TV brightness settings depending on the time of day, So it's always easy on the eyes.
Samsung QE65LS03BGU The Frame LS03B Series - 65" LED-backlit LCD TV - QLED - 4K
LED-backlit LCD TV - QLED - Smart TV
Diagonal Class
65"
Platform
Tizen OS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
HDR Format
HDR10+
HDR Technology
Hybrid Log-Gamma (HLG), Quantum HDR, HDR10+ Adaptive, HDR10+ Gaming
Frame Rate & Enhancement Technology
100 Hz Refresh Rate
Video Interface
HDMI
HDMI Ports Qty
4 ports
Wi-Fi, LAN, Bluetooth
LCD Backlight Technology
Quantum Dot technology, Dual LED Supreme UHD dimming
Image Aspect Ratio
16:9
TV Tuner
1x analogue, 1x digital
Digital TV Tuner
DVB-C, DVB-S2, DVB-T2
Internet Streaming Services
HbbTV 2.0.3, Samsung TV PLUS
Picture Enhancements
100% Color Volume, Dynamic Black EQ, AI Upscale, Wide Viewing Angle, One Billion Colour, Real Depth Enhancer, LED Clear Motion, Noise Reduction
Speaker System
2.0.2 channel
Sound Effects
Dolby Digital MS12
Platform
SmartThings
Intelligent Assistant
Alexa, Bixby, Google Assistant (not available for some languages and countries)
USB
2 ports
Samsung TM2281E remote control
Voltage
AC 220-240 V (50/60 Hz)
Energy Class
Class G
112 watt
Power Consumption Stand by
0.5 watt
145.68 cm x 2.49 cm x 83.19 cm
22.4 kg
Energy Class
Class G
Energy Class (HDR)
Class G
Power Consumption (Max)
215 watt
112 watt
112 kWh/1000h
Power Consumption HDR (On mode)
214 kWh/1000h
Diagonal Class
65"
Series
Model Year
2023
Platform
Tizen OS
HDR Capable
HDR Format
HDR10+
HDR Technology
Video Processor
Quantum 4K
TV Tuner
TV Tuner Presence
Extended PVR
Sensors
Eco Sensor, motion sensor, brightness sensor
Video Interface
HDMI
HDMI Ports Qty
4 ports
Modes
Film Mode, Eye Comfort Mode, Art Mode, Decor Mode, Auto Game Mode, Game Motion Plus, Auto Low Latency Mode (ALLM), Ambient Mode, Filmmaker Mode, HGIG Mode
Design
Very Narrow Bezel Design (VNB), Modern Frame Design, Slim look
Dimensions
Without stand
145.68 cm
2.49 cm
83.19 cm
22.4 kg
Enclosure Colour
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
100 Hz Refresh Rate
Quantum Dot technology, Dual LED - Supreme UHD dimming
Coating
Anti-glare
Display Menu Language
Multilingual
HDMI quick switch, Auto Motion Plus, Smart Calibration, E-Manual, time-shift, One Connect Box, Instant On, Motion Detection, Brightness/Colour Detection, Customizable Frame, Microsoft 365 Cloud, Super Ultra Wide Game View, Wireless Dex, Mobile camera support, Mini Map Zoom, Gaming Hub, SlimFit Cam support, App Casting, Music Wall, FreeSync Premium Pro
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Stand Colour
Flat Panel Mount Interface
400 x 300 mm
VESA Compatibility
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
HDTV Tuner
Digital TV Service
HbbTV
Video Features
Teletext
Electronic Programme Guide
Digital EPG
Media Player
USB Port
USB Ports Qty
2
Remote Control
Remote control
Remote Control Model
Samsung TM2281E
Battery Included
Samsung Smart Control included
Audio System
Digital Audio Format
Dolby Digital Plus output, Dolby Atmos
Surround Mode
Sound Effects
Dolby Digital MS12
Speaker System
2.0.2 channel
Output Power / Total
40 watt
Bluetooth Audio Streaming, Audio Return Channel (ARC), Enhanced Audio Return Channel (eARC), Audio Pre-selection Descriptor, Object Tracking Sound, Adaptive Sound+, Q-Symphony, Active Voice Amplifier (AVA), Dual Audio support, built-in Dolby Digital 5.1 decoder
Network & Internet Multimedia
Functionality
WEB browsing, Internet video playback
LAN Protocol
Ethernet
Wi-Fi Protocol
802.11ac
Bluetooth Version
Bluetooth 5.2
Connect & Share
Wi-Fi Direct, Screen Mirroring, USB Human Interface Device (HID), ConnectShare, Bluetooth Human Interface Device (HID), Sound Mirroring, IP Control, Media Home, Tap View, Multi View, Smart Hub
Supported Consumer Electronics Control (CEC)
Anynet Plus, Multiroom Link
Application Store
Art Store
DLNA
Connector Type
4 x HDMI , 2 x USB , Digital audio output (optical) , LAN , USB-C (camera only) , RS-232C
Internet of Things (IoT)
Platform
SmartThings
HGiG, IPv6
Power supply
Input Voltage
0.5 watt
Auto On/Off
Dimensions & Weight Details
Panel without stand - 145.68 cm x 2.49 cm x 83.19 cm x 22.4 kg , Panel with stand - 145.68 cm x 26.09 cm x 86.89 cm x 22.8 kg , Stand - 107.68 cm x 26.09 cm
Width (Shipping)
161.4 cm
Depth (Shipping)
19.1 cm
Height (Shipping)
95 cm
Weight (Shipping)
35.4 kg
