Samsung 64GB PRO Endurance Micro-SD + AD
Quicklinx: GY7ZWS00 Mfr#: MB-MJ64KA/EU
Take the worry out of always-on recording. Engineered to deliver long-lasting performance, the Samsung PRO Endurance is a great fit for CCTV, dash cams, and body cams. Capture your crucial moments in high-resolution, even in harsh conditions.
  • Record and play in Full HD/4K
    The PRO Endurance optimizes handling of large video files with read/write speeds up to 100/40 MB/s. Plus, Full HD and 4K resolution support ensures that crucial moments are recorded in immense clarity and detail for the times you need them the most.
  • Critical data, protected
    From severe weather to extensive wear and tear, the PRO Endurance stands up to real-world situations.
Samsung PRO Endurance MB-MJ64KA - flash memory card - 64 GB - microSDXC UHS-I
Flash memory card
microSDXC UHS-I Memory Card
Storage Capacity
64 GB
Speed Rating
Video Class V10 / UHS-I U1 / Class10
Enclosure Colour
White
Included Memory Adapter
microSDXC to SD adapter
3-year warranty
Flash memory card
Storage Capacity
64 GB
Enclosure Colour
White
Speed Class
Read Rate
Up to 100 MB/s
Write Rate
Up to 30 MB/s
Magnetic-proof, waterproof, X-ray-proof, temperature-proof
Limited warranty - 3 years
15 mm
11 mm
Thickness
1 mm
0.25 g
-25 °C
85 °C
0 - 93%
