More space and higher speed. Free up your devices with large capacity and high read/write speeds, perfect for 4K UHD video. With astonishing performance and reliability, EVO Plus lets you save and treasure the richness of life.
Simply the right card
More space and higher speed. Free up your devices with large capacity and high read/write speeds, perfect for 4K UHD video. With astonishing performance and reliability, EVO Plus lets you save and treasure the richness of life. -
Fulfill your need for speed
Record and play 4K UHD video without glitches. Shoot flawless high quality photos and videos, and share them all in an instant. -
Extended compatibility
Compatible with a wide range of devices for both SD and micro SD. You can even capture detailed 4K UHD video. -
4-proof protection
Your experiences are irreplaceable, and now unforgettable. Backed by 4-proof protection, the EVO Plus can withstand hours in seawater, extreme temperatures, airport X-ray machines and magnetic fields.
- Samsung EVO Plus MB-MC64HA - flash memory card - 64 GB - microSDXC UHS-I
- Product Type
- Flash memory card
- Form Factor
- microSDXC UHS-I Memory Card
- Storage Capacity
- 64 GB
- Speed Rating
- UHS-I U3 / Class10
- Included Memory Adapter
- microSDXC to SD adapter
- 10 years warranty
- Product Type
- Flash memory card
- Storage Capacity
- 64 GB
- Speed Class
- Read Rate
- Up to 100 MB/s
- Write Rate
- Up to 20 MB/s
- Form Factor
- Magnetic-proof, waterproof, X-ray-proof, temperature-proof
- Limited warranty - flash memory card - 10 years , Limited warranty - adapter - 1 year
- 15 mm
- 11 mm
- Thickness
- 1 mm
- 0.5 g
- -25 °C
- 85 °C
