A modern take on a classic. The next generation Bar Plus elevates the flash drive to an everyday essential, offering impressive speed and striking design. Fit to your hand, the metal unibody is pure minimalism in a drive that cleverly blends style, speed, and reliability.
                Move files in a flashGet your time back. Fast and convenient read speeds up to 200 MB/s with the USB 3.1 standard give you more time to work, play, watch, and create.
                Rugged refinementAs strong as it is stylish. The sturdy metal body keeps your data safe and intact, and the integrated keyring prevents accidental misplacement or loss. The Bar Plus is the ideal combination of stunning design and worry-free durability.
- Samsung BAR Plus MUF-64BE4 - USB flash drive - 64 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.1 Gen 1
- Storage Capacity
- 64 GB
- Enclosure Colour
- Titan grey
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 64 GB
- Enclosure Colour
- Titan grey
- Read Rate
- Up to 200 MB/s
- Interface Type
- USB 3.1 Gen 1
- Shockproof, magnetic-proof, waterproof, X-ray-proof, temperature-proof, metal body, key ring loop
- Limited warranty - 5 years
- 15.46 mm
- 12 mm
- 40 mm
- 11.5 g
- 0 °C
- 60 °C
