Samsung 64GB Bar Plus USB 3.1 - Champagne Silver
Quicklinx: G6YQWS00 Mfr#: MUF-64BE3/APC
Capacity: 64GB
Interface: USB 3.1 Gen 1
27 In Stock
£22.89 ex VAT
£27.46 inc VAT
A modern take on a classic. The next generation Bar Plus elevates the flash drive to an everyday essential, offering impressive speed and striking design. Fit to your hand, the metal unibody is pure minimalism in a drive that cleverly blends style, speed, and reliability.
  • Move files in a flash
    Get your time back. Fast and convenient read speeds up to 200 MB/s with the USB 3.1 standard give you more time to work, play, watch, and create.
  • Rugged refinement
    As strong as it is stylish. The sturdy metal body keeps your data safe and intact, and the integrated keyring prevents accidental misplacement or loss. The Bar Plus is the ideal combination of stunning design and worry-free durability.
Samsung BAR Plus MUF-64BE3 - USB flash drive - 64 GB
USB flash drive
Interface Type
USB 3.1 Gen 1
Storage Capacity
64 GB
Enclosure Colour
Champagne silver
5-year warranty
USB flash drive
Storage Capacity
64 GB
Enclosure Colour
Champagne silver
Read Rate
Up to 200 MB/s
Interface Type
USB 3.1 Gen 1
Shockproof, magnetic-proof, waterproof, X-ray-proof, temperature-proof, metal body, key ring loop
Limited warranty - 5 years
15.46 mm
12 mm
40 mm
11.5 g
60 °C
Capacity: 64GB
Brand: Samsung
