Discover the Samsung MUF-512DA, a USB flash drive designed to keep up with your active lifestyle. Offering 512 GB of storage capacity, it's suitable for storing all your important files, from high-resolution photos and videos to critical documents. It boasts a read rate of 400 MB/s thanks to its USB 3.2 Gen 1 / USB-C interface, ensuring that your data is always within quick reach.
Durability is at the core of the MUF-512DA's design. It's built to last, with resistance to water, shocks, X-rays, and extreme temperatures, making it your reliable companion in any environment. Whether you're at the office, on a construction site, or exploring the great outdoors, this flash drive is equipped to protect your data against the elements. Its compatibility is broad, meaning it works seamlessly with a wide range of devices, further enhancing its versatility as a storage solution.
Robust design
Designed to withstand the elements, this USB flash drive is X-ray-resistant, magnetic-proof, shockproof, temperature-proof, and waterproof, making it an ideal choice for users who demand durability in various environments. -
High-speed connectivity
Equipped with USB 3.2 Gen 1 / USB-C interface, it offers fast data transfer speeds of up to 400 MB/s, ensuring quick and efficient access to files when you need them most. -
Generous storage
With a storage capacity of 512 GB, this flash drive provides ample space for storing documents, photos, music, and videos, making it a versatile storage solution for both personal and professional use.
 - Samsung MUF-512DA - USB flash drive - 512 GB
- Product Type
 - USB flash drive
- Interface Type
 - USB 3.2 Gen 1 / USB-C
- Storage Capacity
 - 512 GB
- Enclosure Colour
 - Blue
- Technology
 - NAND Flash
- Software Included
 - Samsung Magician Software
 - 5-year warranty
- Product Type
 - USB flash drive
- Storage Capacity
 - 512 GB
- Enclosure Colour
 - Blue
- Read Rate
 - Up to 400 MB/s
- Interface Type
- Technology
 - NAND Flash
 - Shockproof, magnetic-proof, waterproof, temperature-proof, X-ray-resistant
- Software Included
 - Limited warranty - 5 years
 - 33.7 mm
 - 6.4 mm
 - 15.9 mm
 - 3.4 g
 - 0 °C
 - 60 °C
