Samsung 512GB USB Type-C Flash Drive - Blue
Quicklinx: HXZSWS00 Mfr#: MUF-512DA/APC
Hurry, only 1 left in stock!
£108.74 ex VAT
£130.48 inc VAT
Discover the Samsung MUF-512DA, a USB flash drive designed to keep up with your active lifestyle. Offering 512 GB of storage capacity, it's suitable for storing all your important files, from high-resolution photos and videos to critical documents. It boasts a read rate of 400 MB/s thanks to its USB 3.2 Gen 1 / USB-C interface, ensuring that your data is always within quick reach.
Durability is at the core of the MUF-512DA's design. It's built to last, with resistance to water, shocks, X-rays, and extreme temperatures, making it your reliable companion in any environment. Whether you're at the office, on a construction site, or exploring the great outdoors, this flash drive is equipped to protect your data against the elements. Its compatibility is broad, meaning it works seamlessly with a wide range of devices, further enhancing its versatility as a storage solution.
  • Robust design
    Designed to withstand the elements, this USB flash drive is X-ray-resistant, magnetic-proof, shockproof, temperature-proof, and waterproof, making it an ideal choice for users who demand durability in various environments.
  • High-speed connectivity
    Equipped with USB 3.2 Gen 1 / USB-C interface, it offers fast data transfer speeds of up to 400 MB/s, ensuring quick and efficient access to files when you need them most.
  • Generous storage
    With a storage capacity of 512 GB, this flash drive provides ample space for storing documents, photos, music, and videos, making it a versatile storage solution for both personal and professional use.
Samsung MUF-512DA - USB flash drive - 512 GB
USB flash drive
Interface Type
Storage Capacity
512 GB
Enclosure Colour
Blue
NAND Flash
Software Included
Samsung Magician Software
5-year warranty
USB flash drive
Storage Capacity
512 GB
Enclosure Colour
Blue
Read Rate
Up to 400 MB/s
Interface Type
NAND Flash
Shockproof, magnetic-proof, waterproof, temperature-proof, X-ray-resistant
Software Included
Limited warranty - 5 years
33.7 mm
6.4 mm
15.9 mm
3.4 g
60 °C
Brand: Samsung
