The Samsung M3 Portable External Hard Drive delivers handy portable storage. It is easy to take wherever you go, and has ample capacity of 500GB. The durable black design stands up to the rigors of daily use.
- Handy portable storage
- Durable black design
- SafetyKey protection for your data
Contents
- M3 Portable External Hard Drive
- USB cable
- Quick Install Guide
- Software preloaded on the drive
- Electronic User Documentation (PDF)
- Windows 7/Vista/XP, Mac OS X 10.4.8 or later
- SuperSpeed USB 3.0 (Max): 4.8Gb/s
- Temperature (operating): 5° to 40°C (41° to 104°F)
- Temperature (nonoperating): -20° to 65°C (-4° to 149°F)
- Weight (Max): 141g (500GB)
- Height (Max): 17.5mm (500GB)
- Width: 82mm
- Length: 112mm
- 3-year limited warranty
Software
- AutoBackup personal backup solution
- Secure Manager for worry-free data security
- SecretZoneTM can encrypt data on the device
- Samsung M3 Portable STSHX-M500TCB - hard drive - 500 GB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 500 GB
- Form Factor
- 2.5"
- Interface
- USB 3.0
- Samsung Auto Backup, SafetyKey, SecretZone
- Power Source
- USB bus
- Enclosure Colour
- Black
- 8.2 cm x 11.2 cm x 2 cm
- 151 g
- 3-year warranty
- Capacity
- 500 GB
- Form Factor
- 2.5"
- Interface
- USB 3.0
- 8.2 cm
- 11.2 cm
- 2 cm
- 151 g
Expansion & Connectivity
- 1 x USB 3.0 - 9 pin USB Type A
- Compatible Bay
- 2.5"
- Power Source
- USB bus
- OS Required
- Microsoft Windows Vista / XP / 7, Apple MacOS X 10.4.8 or later
- Cables Included
- 1 x USB cable
- Enclosure Colour
- Black
- Limited warranty - 3 years
- 5 °C
- 40 °C
