Unleash the power of the Samsung PCIe 4.0 NVMe SSD 980 PRO for your next-level computing. Leveraging the PCIe 4.0 interface, the 980 PRO delivers double the data transfer rate of PCIe 3.0 while being backward-compatible for PCIe 3.0 for added versatility.
Powered by Samsung custom Elpis Controller for PCIe 4.0 SSD, the 980 PRO is optimized for speed. It delivers read speeds up to 7,000 MB/s, making it 2 times faster than PCIe 3.0 SSDs and 12.7 times faster than SATA SSDs. The 980 PRO achieves maximum speeds on PCIe 4.0 and may vary in other environments.
A winning combination
Designed with hardcore gamers and tech-savvy users in mind, the 980 PRO offers high-performance bandwidth and throughput for heavy-duty applications in gaming, graphics, data analytics, and more. It's fast at loading games so you can play more and wait less. -
Efficient M.2 SSD
The 980 PRO comes in a compact M.2 2280 form factor, which can be easily plugged into desktops and laptops for maximum board design flexibility. The drive is suitable for building high-performance computing systems due to its optimized power efficiency. -
Reliable thermal control
High-performance SSDs usually require high-performance thermal control. To ensure stable performance, the 980 PRO uses nickel coating to help manage the controller's heat level and a heat spreader label to deliver effective thermal control of the NAND chip. -
Smart thermal solution
Embedded with Samsung's cutting-edge thermal control algorithm, the 980 PRO manages heat on its own to deliver durable and reliable performance. To minimize performance fluctuations in the long haul, Samsung's Dynamic Thermal Guard technology maintains the 980 PRO's temperature at optimal levels. -
Samsung Magician software
Unlock the full power of the 980 PRO with Samsung Magician's intuitive yet advanced optimization tools. Monitor drive health, optimize performance, protect valuable data, and receive important updates with Samsung Magician to ensure you're always getting the best performance out of your SSD.
- Samsung 980 PRO MZ-V8P500BW - SSD - 500 GB - PCIe 4.0 x4 (NVMe)
- Solid state drive - internal
- Capacity
- 500 GB
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES
- Form Factor
- M.2 2280
- Interface
- Buffer Size
- 512 MB
- TRIM support, sleep mode, Auto Garbage Collection Algorithm, TurboWrite Technology, Low Power DDR4 SDRAM Cache, NVM Express (NVMe) 1.3c, Samsung V-NAND 3bit MLC Technology, Samsung Elpis Controller, S.M.A.R.T.
- 22.15 mm x 80.15 mm x 2.38 mm
- 9 g
- 5-year warranty
- Designed For
- Intel Next Unit of Computing 13 Extreme Kit - NUC13RNGi5, 13 Extreme Kit - NUC13RNGi7
- Capacity
- 500 GB
- 256-bit AES
- Form Factor
- M.2 2280
- Interface
- Buffer Size
- 512 MB
- 22.15 mm
- 80.15 mm
- 2.38 mm
- 9 g
Performance
- SSD Endurance
- 300 TB
- Internal Data Rate
- 6900 MBps (read) / 5000 MBps (write)
- 4KB Random Read
- 22000 IOPS
- 4KB Random Write
- 60000 IOPS
- Maximum 4KB Random Write
- 1000000 IOPS
- Maximum 4KB Random Read
- 800000 IOPS
Reliability
- MTBF
- 1,500,000 hours
Expansion & Connectivity
- PCI Express 4.0 x4 (NVMe) - M.2 Card
- Compatible Bay
- M.2 2280
- Power Consumption
- 5.9 Watt (average) , 7.4 Watt (maximum) , 0.035 Watt (idle)
- Software Included
- Samsung Magician Software
- IEEE 1667
- Limited warranty - 5 years
- 0 °C
- 70 °C
- Shock Tolerance (operating)
- 1500 g @ 0.5 ms
- Designed For
