Samsung 4TB T9 Portable SSD
Quicklinx: HGF5WS00 Mfr#: MU-PG4T0B/EU
Form Factor: [N/A]
Capacity: 4TB
Interface: USB 3.2 Gen 2x2
Type: External hard drive
13 In Stock
£311.77 ex VAT
£374.12 inc VAT
  • Robust protection
    Equipped with up to 3 m to concrete drop protection and password authentication, this portable hard drive ensures your data remains safe and secure, no matter where you go.
  • High-speed transfers
    With an interface speed of 20 Gbps (USB 3.2 Gen 2x2) and a max data transfer rate of 2000 MB/s, transferring large files is both fast and efficient, making it ideal for professionals on-the-move.
  • Expansive storage
    Boasting a generous 4 TB capacity, this external hard drive provides ample space for storing documents, photos, and videos, all in a compact, portable form factor.
  • Seamless connectivity
    Featuring a USB-C port and including both USB-C and USB-C to USB-A cables, this hard drive offers versatile connectivity options, ensuring compatibility with a wide range of devices.
  • Durable and compliant
    This hard drive meets numerous compliance standards, including FCC, RoHS2, and more, ensuring a reliable and environmentally friendly storage solution.
Samsung T9 MU-PG4T0B - SSD - 4 TB - USB 3.2 Gen 2x2
Solid state drive - external (portable)
4 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
USB 3.2 Gen 2x2 - USB-C
Data Transfer Rate
Password authentication, up to 3m to concrete drop protection
Power Source
USB bus
Enclosure Colour
60 mm x 88 mm x 14 mm
122 g
Europe
5-year warranty
4 TB
Hardware Encryption
256-bit AES
USB 3.2 Gen 2x2
60 mm
88 mm
14 mm
122 g
Performance
Interface Transfer Rate
Max Data Transfer Rate
2000 MB/s
Internal Data Rate
2000 MBps (read) / 1950 MBps (write)
Expansion & Connectivity
1 x USB 3.2 Gen 2x2 - 24 pin USB-C
Power Source
USB bus
Apple MacOS, Android, Windows
USB-C cable , USB-C to USB-A cable
UL, TUV, VCCI, BSMI, CB, IC, FCC, KC, RoHS2, EAC, RCM, BIS, UASP (USB Attached SCSI Protocol), UKCA
Enclosure Colour
Europe
Limited warranty - 5 years
60 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
Form Factor: [N/A]
Capacity: 4TB
Brand: Samsung
