Samsung 4TB 870 QVO V-NAND SATA 6Gb/s SSD
Quicklinx: FXW8WS00 Mfr#: MZ-77Q4T0BW
Form Factor: 2.5
Capacity: 4TB
Interface: Serial ATA-600
Type: Internal hard drive
Hurry, only 1 left in stock!
£317.29 ex VAT
£380.74 inc VAT
The 870 QVO offers an incredible upgrade for everyday PC users who want to ramp-up their desktop PC or laptop to a larger storage without compromising on performance.
  • Enhanced in every way
    The 870 QVO features improved random speed and sustained performance. Intelligent TurboWrite accelerates write speeds and maintains long-term high performance with a larger variable buffer.
  • Reliable and sustainable
    The groundbreaking capacity of the 870 QVO increases its reliability. This formidable SSD provides further reliability with a refined ECC algorithm that enables a stable performance.
  • Upgrade with ease
    Upgrading to the 870 QVO is made easy for anyone with a desktop PC or laptop that supports a standard 2.5-inch SATA form factor.
Samsung 870 QVO MZ-77Q4T0BW - SSD - 4 TB - SATA 6Gb/s
Solid state drive - internal
4 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
Quad-level cell (QLC)
2.5"
SATA 6Gb/s
Buffer Size
4 GB
TRIM support, Garbage Collection technology, sleep mode, TurboWrite Technology, V-NAND Technology, Low Power DDR4 SDRAM Cache, Samsung MKX Controller, S.M.A.R.T., 256-bit AES, IEEE 1667
69.85 mm x 100 mm x 6.8 mm
54 g
3-year warranty
4 TB
Hardware Encryption
256-bit AES
2.5"
SATA 6Gb/s
Buffer Size
4 GB
69.85 mm
100 mm
6.8 mm
54 g
Performance
SSD Endurance
1.44 PB
Internal Data Rate
560 MBps (read) / 530 MBps (write)
4KB Random Read
11000 IOPS
4KB Random Write
35000 IOPS
Maximum 4KB Random Write
88000 IOPS
Maximum 4KB Random Read
98000 IOPS
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
3.3 Watt (average) , 5.5 Watt (maximum) , 0.045 Watt (idle)
Limited warranty - 3 years
70 °C
Shock Tolerance (operating)
0.5 ms half-sine
Shock Tolerance (non-operating)
1500 g @ 0.5 ms
Form Factor: 2.5
Capacity: 4TB
Brand: Samsung
