Samsung 4TB 860 EVO Pro Series SATA 6Gb/s SSD
Quicklinx: DBCMWS00 Mfr#: MZ-76P4T0B/EU
Form Factor: 2.5"
Capacity: 4TB
Interface: Serial ATA-600
Type: Internal hard drive
More than 50 in stock
£744.08 ex VAT
£892.89 inc VAT
Designed for gamers, IT admins and creative professionals, the Samsung 860 PRO is powered by V-NAND technology and a robust algorithm-based Samsung controller to handle the heavy workloads of high-end client PCs, workstations and NAS. Get fast, enduring performance with exceptional reliability and expanded compatibility.
Samsung 860 PRO MZ-76P4T0B - solid state drive - 4 TB - SATA 6Gb/s
Solid state drive - internal - TRIM support, sleep mode, 3D V-NAND Technology, Auto Garbage Collection Algorithm, eDrive, Samsung MJX Controller, Low Power DDR4 SDRAM Cache
4 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
3D multi-level cell (MLC)
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
4 GB
TRIM support, sleep mode, 3D V-NAND Technology, Auto Garbage Collection Algorithm, eDrive, Samsung MJX Controller, Low Power DDR4 SDRAM Cache, S.M.A.R.T., 256-bit AES, IEEE 1667
6.985 cm x 10 cm x 0.68 cm
62 g
5-year warranty
4 TB
Hardware Encryption
256-bit AES
2.5"
SATA 6Gb/s
Buffer Size
4 GB
6.985 cm
10 cm
0.68 cm
62 g
Performance
SSD Endurance
4800 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
560 MBps (read) / 530 MBps (write)
4KB Random Read
11000 IOPS
4KB Random Write
43000 IOPS
Maximum 4KB Random Write
90000 IOPS
Maximum 4KB Random Read
100000 IOPS
Reliability
MTBF
2,000,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
2.5"
Power Consumption
2.2 Watt (average) , 4.5 Watt (maximum)
Software Included
Samsung Magician Software
WWN, IEEE 1667
Limited warranty - 5 years
70 °C
Shock Tolerance (operating)
1500 g @ 0.5 ms half-sine
Form Factor: 2.5"
Capacity: 4TB
Brand: Samsung
Price Range Ex VAT: 500 - 750
