Complimentary Star Wars: The Last Jedi UHD Blu-Ray disc included in the box when you purchase this UHD Blu-Ray player.
Enjoy revolutionary picture quality the way the director intended it. With 4 times higher the resolution than Full HD, the UBD-M7500 delivers crystal clear and detailed images in UHD, especially on big screens, bringing your movies to life.
True-to-life stunning 4K resolution
Enjoy the incredibly life-like images with true 4K UHD playback. Plus, with the UHD Upscaling feature, all your lower definition content will automatically refine to near UHD quality. -
Lifelike spectrum of colors
Enjoy realistic picture quality like never before. The Ultra HD Blu-ray Player offers twice the color range of existing conventional Blu-ray players and 64 times higher color expression, surpassing the digital cinema standard. -
HDR - stunning brightness, deeper contrast
HDR allows for a greater range of color contrast and brightness, enhancing details from the original film format. -
Get HDR resolution, automatically
Forget the hassle of changing your TV settings. The UBD-M7500 recognizes HDR content and automatically optimizes your Samsung TV settings, so you see content at its best - every time. -
Easy entertainment with a seamless UI
All your content, accessible from one place. Samsung's simple, intuitive SmartHub user interface gives you quick access to key menu features without having to go back to the home screen while playing a disc. -
Enjoy studio-quality sound
Experience professional studio quality sound at home. HD Audio preserves the quality and richness of the original sound through 192 kHz/24bit without down sampling.
- Samsung UBD-M7500 - Blu-ray disc player
- Product Type
- Internet Streaming Services
- Smart Hub
- 40.6 cm x 23 cm x 4.47 cm
- 1.8 kg
- Media Type
- DVD-R, DVD+RW, DVD-RW, DVD+R, DVD, CD, Blu-ray Disc
- Upscaling
- Audio D/A Converter
- 24bit / 192kHz
- Remote Control
- Remote control
- Sound Output Mode
- Stereo
- Power
- AC 230V (50/60 Hz)
- Form Factor
- Tabletop
- Product Type
- Form Factor
- Tabletop
- 40.6 cm
- 23 cm
- 4.47 cm
- 1.8 kg
DVD
- Media Type
- 24bit / 192kHz
- Max Video Resolution
- 4K UHD Video Playback
- Media Load Type
- Tray
- Upscaling
- 4K Upscaling
- Video Formats
- DivX, WMV, MKV, AVCHD
- Photo Formats
- JPEG
Network & Internet Multimedia
- Connectivity Interfaces
- IEEE 802.3 (Ethernet)
- Smart Hub
Blu-ray & DVD Features
- Anynet+, CD ripping, Web Browser, Smart Hub, HDR Compatibility
Audio System
- Sound Output Mode
- Stereo
- Digital Audio Format
- Dolby Digital output, DTS digital output
Remote Control
- Remote control
- Connector Type
- HDMI output (19 pin HDMI Type A) - rear , LAN (RJ-45) - rear , USB - front , Digital audio output (optical) (TOS Link) - rear
- Voltage Required
- 22 Watt
- Power Consumption Stand by
- 0.3 Watt
- Width (Shipping)
- 46.2 cm
- Depth (Shipping)
- 28.6 cm
- Height (Shipping)
- 11.6 cm
- Weight (Shipping)
- 2.8 kg
Samsung 4K UHD Blu-Ray Player UBD-M7500 with HDR Technology
