Samsung 49" G95C DQHD 240Hz Odyssey Gaming Monitor
Quicklinx: HTTHWS00 Mfr#: LS49CG954EUXXU
Diagonal Size: 49in
Max Resolution: 5120 x 1440
Response Time: 1ms
Speakers: None
Interfaces: HDMI, DisplayPort
Hurry, only 1 left in stock!
£845.40 ex VAT
£1,014.48 inc VAT
Discover the gaming experience with the Samsung Odyssey G9 monitor. This 49-inch marvel brings every game to life in Dual Quad HD (5120 x 1440) resolution, supported by a color gamut of 92% DCI-P3 for vivid visuals. The Odyssey G9's 1000R curved screen is designed to wrap around your field of vision, putting you at the center of the action for immersion.
HDR technology takes visual fidelity to new heights with VESA DisplayHDR 1000 certification, ensuring detailed and dynamic images even in the darkest or brightest scenes. Whether you're gaming or streaming, the Odyssey G9's AMD FreeSync Premium Pro compatibility and a high refresh rate of 240 Hz deliver smooth visuals, complemented by a rapid 1 ms response time.
Ergonomics are front and center with adjustable height, swivel, and tilt, allowing you to find the perfect viewing angle. Plus, with its array of connectivity options, including HDMI, DisplayPort, and a built-in USB 3.0 hub, the Samsung Odyssey G9 is versatile. Step into the future of gaming with a monitor that's ready for adventure.
  • Immersive curvature
    Experience immersion with the Samsung Odyssey G9's 1000R screen curvature, designed to match the contours of the human eye for comfort and viewing.
  • Stunning visuals
    Boasting a Dual Quad HD resolution of 5120 x 1440 on a 49-inch display, the Odyssey G9 delivers crisp, vivid images with a 1.07 billion color range, supported by VESA DisplayHDR 1000 certification for brightness and contrast.
  • Seamless gameplay
    With AMD FreeSync Premium Pro technology and a 240 Hz refresh rate, the Odyssey G9 ensures smooth gaming experiences, complemented by a 1 ms response time for quick, precise actions.
  • Ergonomic design
    Adjust your setup with ease, thanks to the monitor's height, swivel, and tilt adjustments, allowing for a comfortable and personalized viewing experience.
  • Advanced connectivity
    Equipped with multiple input options including 2xHDMI, DisplayPort, and a built-in USB 3.0 hub, the Odyssey G9 offers versatile connectivity for all your gaming and multimedia needs.
Samsung Odyssey G9 S49CG954EU - G95C Series - LED monitor - curved - 49" - HDR
LED-backlit LCD monitor - 49"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/1762586
Energy Class
Class G
Energy Consumption per Year
66 kWh
Curved Screen
Adaptive-Sync Technology
USB 3.0 hub
Panel Type
VA
Aspect Ratio
32:9
Native Resolution
Dual Quad HD 5120 x 1440 at 240 Hz
Brightness
450 cd/m²
Contrast Ratio
2500:1
HDR Capable
HDR10+ / DisplayHDR 1000
Response Time
1 ms (grey-to-grey)
Gaming
Colour Support
1.07 billion colours
Colour Gamut
92% DCI-P3 (CIE 1976)
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Height, swivel, tilt
Voltage
AC 100-240 V
114.76 cm x 42.05 cm x 56.84 cm
15.6 kg
Display Type
Energy Class
Class G
Energy Class (HDR)
Class G
66 kWh
Diagonal Size
49"
Curved Screen
Yes (1000R)
Built-in Devices
USB 3.0 hub
Panel Type
VA
Aspect Ratio
32:9
Native Resolution
Brightness
450 cd/m²
Contrast Ratio
2500:1
HDR Format
HDR10+
HDR Certification
DisplayHDR 1000
Colour Support
Colour Gamut
Response Time
1 ms (grey-to-grey)
Gaming
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Picture by picture, game mode, Mega Dynamic Contrast Ratio, Black eQualizer, CustomColor Mode, FPS Mode, Flicker Free technology, RTS Mode, Image Size, Eye Saver Mode, Factory Tunning, Factory Calibration Report, Off Timer Plus, Sports Mode, Low Input Lag, Super Arena Gaming UX, Refresh Rate Optimizer, RPG Mode, Picture-in-Picture, Auto Source Switch+, Adaptive Picture, CoreSync lighting design, Virtual AIM Point, Entertain Mode, Graphic Mode, Eco Mode, HDR10+ Gaming
114.76 cm x 42.05 cm x 56.84 cm - with stand
15.6 kg
DisplayPort 1.4 (HDCP 2.2) , 2 x HDMI (HDCP 2.2) , Headphone jack , 2 x USB 3.0
Mechanical
Tilt Angle
-2/+11
Swivel Angle
30
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable , 1 x DisplayPort cable , 1 x USB 3.0
Input Voltage
AC 100-240 V
45 kWh/1000h
Power Consumption HDR (On mode)
147 kWh/1000h
Power Consumption (Typical)
45 Watt
Power Consumption (Max)
180 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 114.76 cm - depth: 42.05 cm - height: 56.84 cm - weight: 15.6 kg , Without stand - width: 114.76 cm - depth: 29.38 cm - height: 36.35 cm - weight: 10.6 kg
Shipping Width
126.5 cm
Shipping Depth
48.1 cm
Shipping Height
36.6 cm
Shipping Weight
20.6 kg
10 °C
10 - 80% (non-condensing)
Diagonal Size: 49in
Response Time: 1ms
Speakers: None
Interfaces: HDMI
Interfaces: DisplayPort
Brand: Samsung
Price Range Ex VAT: £750 - £1000
