Bridging the gap between enterprise storage and cache memory with ultra-low latency. The 983 ZET bridges the gap between storage memory and cache memory by offering a new level of performance with ultra-low latency, high QoS, breakthrough speeds and ultra-high reliability. Ideal for high-performance computing applications such as hybrid caching servers, database servers, AI and IoT, the 983 ZET is a perfect companion to Samsung's DCT SSDs as a powerful cache memory solution to completely enhance server performance.
- Samsung 983 ZET MZ-PZA480BW - SSD - 480 GB - PCIe 3.0 x4 (NVMe)
- Solid state drive - internal (desktop)
- Capacity
- 480 GB
- Hardware Encryption
- Form Factor
- PCIe card (HHHL)
- Interface
- Buffer Size
- 1.5 GB
- TRIM support, Auto Garbage Collection Algorithm, V-NAND Technology, Low Power DDR4 SDRAM Cache, Samsung Phoenix Controller, S.M.A.R.T.
- 69.9 mm x 167.7 mm x 18.8 mm
- 330 g
- 5-year warranty
- Capacity
- 480 GB
- Form Factor
- PCIe card (HHHL)
- Interface
- Buffer Size
- 1.5 GB
- 69.9 mm
- 167.7 mm
- 18.8 mm
- 330 g
Performance
- SSD Endurance
- 7.44 PB
- Internal Data Rate
- 3400 MBps (read) / 3000 MBps (write)
- Maximum 4KB Random Write
- 60000 IOPS
- Maximum 4KB Random Read
- 750000 IOPS
Reliability
- MTBF
- 2,000,000 hours
Expansion & Connectivity
- 1 x PCI Express 3.0 x4 (NVMe) - PCI Express
- Compatible Bay
- PCIe card (HHHL)
- Power Consumption
- 9 Watt (typical) , 5.5 Watt (idle)
- Software Included
- Samsung SSD Magician DC
- Limited warranty - 5 years
- 0 °C
- 55 °C
- Shock Tolerance (operating)
- 1500 g @ 0.5 ms half-sine
