Samsung 43" M70A UHD Smart Monitor
Quicklinx: GQW1WS00 Mfr#: LS43AM700UUXXU
The World's 1st Do-It-All Screen - Get work done without a PC, with the installed Microsoft Office 365, or by remote access to your office computer. Then switch to pure entertainment with the on-board Smart Hub
Stream endless, picture perfect entertainment - Binge watching got even easier. with 4K Ultra HD. Access a bunch of entertainment apps, such as Netflix, YouTube, and Disney+, without switching on your PC or laptop. The remote control and built-in speakers simplify your chill time.
USB type-C - The USBC port enables you to power up, transmit data, and even send display signals between devices with just one connection. Its single connection architecture brings an enjoyable work environment that's both clutter-free and stress-free.
Samsung S43AM700UU - M70A Series - LED monitor - 4K - 43" - HDR
LED-backlit LCD monitor - 43" - Smart monitor
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/623924
Energy Class
Class G
Energy Consumption per Year
93 kWh
Power Consumption (On mode)
67 W
USB 2.0 hub, 802.11a/b/g/n/ac network adapter, Bluetooth 4.2 adapter, USB PD 65 Watt
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Brightness
300 cd/m²
Contrast Ratio
5000:1
HDR Capable
HDR10
Response Time
8 ms (grey-to-grey)
Colour Support
1 billion colours
Input Connectors
2xHDMI, USB-C
Display Position Adjustments
Tilt
Voltage
AC 100-240 V
96.55 cm x 24.72 cm x 62.93 cm
10.6 kg
CEC
Display Type
LED-backlit LCD monitor / TFT active matrix - Smart monitor
Energy Class
Class G
Energy Class (HDR)
Class G
93 kWh
Diagonal Size
43"
Built-in Devices
USB Power Delivery
65 Watt
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
5000:1
HDR Format
HDR10
Colour Support
1 billion colours
Response Time
8 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Game mode, ConnectShare, Flicker Free technology, Eye Saver Mode, DLNA, Auto Source Switch+, Adaptive Picture, Ultrawide Game View, Tizen Platform, Tap View, Remote Access, Sound Mirroring, SmartThings App Support
96.55 cm x 24.72 cm x 62.93 cm - with stand
10.6 kg
Audio
Speakers
2 x HDMI , USB-C (power up to 65W) , 3 x USB 2.0
Mechanical
Tilt
Tilt Angle
-2/+20
VESA Mounting Interface
200 x 200 mm
AirPlay, screen mirroring, Samsung DeX, Bixby Voice Assistant
Remote control
1 x HDMI cable
CEC
Input Voltage
AC 100-240 V
67 W
67 kWh/1000h
Power Consumption HDR (On mode)
74 kWh/1000h
Power Consumption (Typical)
67 Watt
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
With stand - width: 96.55 cm - depth: 24.72 cm - height: 62.93 cm - weight: 10.6 kg , Without stand - width: 96.55 cm - depth: 2.57 cm - height: 55.98 cm - weight: 8.5 kg
Shipping Width
119.8 cm
Shipping Depth
15.9 cm
Shipping Height
67.7 cm
Shipping Weight
13.7 kg
10 °C
10 - 80% (non-condensing)
