Samsung 400GB G2 Portable USB 2.0 2.5" Black
PRICED TO CLEAR - WHILST STOCKS LAST
Quicklinx: 7C5VWS00 Mfr#: HX-MU040DC/GB2
Key Features
Trendy Design
  • Highly differentiated "Green" design modeled on baobab tree
  • Multi-angle glittering cover
  • Embossed surface like leaves with natural colors
Eco Triangle
  • Low power consumption
  • Low acoustic noise
  • Eco-friendly components
Data Backup and Security
  • Samsung Auto Backup
  • SecretZone
  • 3-year Limited Warranty
  • Hi-Speed USB (Max.): 480 Mbps
  • Operating System: Windows 2000 Pro / XP / Vista / 7 / Mac OS X 10.4.8 or later
  • Length: 111.3 mm (4.38 inches)
  • Height: 17 mm (0.62 inches)
  • Width: 79 mm (3.11 inches)
Package Contents
  • G2 Portable external hard drive
  • USB cable (45cm)
  • Quick start guide
  • Electronic user document (PDF)
  • G2 series drive's distinctive design
    G2 Portable drive's multi-faceted external case sparkles in the sun, much like sunlight filtering through leaves of a baobab tree swaying in the wind. The smooth, rounded corners make it easy to carry and its environment-friendly case is also scratch-resistant.
  • Benefits of a small and light and light external hard drive
    USB on-board technology is more structurally stable, smaller, lighter, and has lower power consumption than separate USB controllers and hard drives.
  • The G series, eco-friendly hard drive
    The G2 Portable drive series features Samsung's Eco green hard drive technology which meets RoHS standards while eliminating TBBP-A and halogen components. The G series drive also features lower noise and power consumption.
  • The key to worry-free data security
    Protect your confidential information with Samsung's external hard drive. It features two distinct forms of critical protection for your data. Safetykey safeguards your back-up data. With both password while SecretZone creates a virtual encryption, your data is safe so you can rest easy.
  • A hard drive that's easy to use
    Engineered for absolute ease, Samsung hard drive offers complete convenience with user-friendly features. Its capacity gauge lets you quickly see how much storage space you have used, how much is left and what is designated as backup. And Plug and Play lets you forego the usual CD for quick and easy installation.
2.5"
400 GB
Hi-Speed USB
Resources
The following resources are available for the Samsung 400GB G2 Portable USB 2.0 2.5" Black
