Samsung 40" SM400 DX3 8MS 1920 x 1080 LFD
Quicklinx: 7G2SWS00 Mfr#: LH40CSPLBC/EN
  • 1080p
Give your business communications the quality it deserves with an ultra bright LFD like the 550DX Series. It combines a high performance with durability to deliver a totally professional service. The DID panel and crystal clear picture ensure that your screen stands out amongst competitors. And for even greater impact, you can simply connect them to create a video wall. The 550DX also features the latest in connectivity with various ports and management software, which lets you minimise the time taken to complete maintenance and any software upgrades. Make your workload easier with an LFD like the 550DX.
  • Choose The Right View, Landscape Or Portrait
    This Samsung LFD gives you the flexibility to display your image vertically or horizontally—whatever the situation calls for. With a pivot function that rotates the screen 90°degrees and the freedom to display presentations in portrait mode or advertisements in landscape mode, this makes for one versatile monitor.
  • A Smart Sensor That Automatically Saves Energy
    Stop worrying about the lighting conditions affecting your display. This Samsung LFD adjusts its brightness levels as ambient light changes so your images are always crystal-clear. And while it compensates for low-light and high-light environments, you'll save energy and stay eco-friendly.
  • Save money, save space with built-in speakers
    Maximise your impact with a great picture and crisp audio. Your message will be heard loud and clear with built-in speakers. You'll save money when you eliminate the cost of purchasing separate speakers, and you'll save valuable space as well.
  • Enhanced connectivity without extra costs
    Create a professional digital display without having to purchase any extras—like a distributor or external equipment. Samsung makes it easy with a display port that delivers enhanced connectivity and an improved display interface. With a simple adapter, you can connect your PC, monitor or TV using an HDMI or DVI cable that's more than twice as long as standard cables. Discover an easy, cost-effective way to create a powerful display.
  • Set a schedule that's always on time
    Keep your monitor running efficiently at all times. This Samsung LFD boasts a smart scheduling feature. The automatic power on/off function allows you to designate time, day, volume, input source and holiday dates. There's even a convenient on-screen display setting with up to 3 schedules including day and time.
Samsung 400DX-3 40" LCD flat panel display - Full HD - for digital signage
Diagonal Class
40"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Video Interface
Composite, HDMI
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
S-PVA
Image Aspect Ratio
16:9
TV Tuner
No tuner
Sound Output Mode
Stereo
Speaker System
2 speakers
Remote control
Microsoft Certification
Compatible with Windows 7
Voltage
200 Watt
Power Consumption Stand by
2 Watt
93.2 cm x 13 cm x 54.8 cm
17 kg
Environmental Standards
ENERGY STAR Qualified
200 Watt
Diagonal Class
40"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
Composite, HDMI
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
93.2 cm
13 cm
54.8 cm
17 kg
Display
LCD Display Technology
S-PVA
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
Colour Depth
16.7 million colours
Image Contrast Ratio
3000:1
Dynamic Contrast Ratio
10000:1
Brightness
700 cd/m²
Colour Gamut
72% (NTSC)
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.46125 x 0.46125mm
Response Time
8 ms
Max V-Sync Rate
85 Hz
Max H-Sync Rate
81 kHz
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Remote Control
Remote control
Audio System
Sound Output Mode
Stereo
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Connector Type
DVI-D input , VGA / component video input , DisplayPort , Audio line-in , Composite video input , HDMI , Audio line-in , 2 x serial
VGA cable
CSA, UL, TUV, VCCI, C-Tick, BSMI, GOST, NEMKO, NOM, PCBC, SASO, SIQ, FCC Part 15 B, CCC, FCC Part 15, PSB, IRAM, KCC
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
5.0
Power supply - internal
Input Voltage
2 Watt
Width (Shipping)
104 cm
Depth (Shipping)
29.5 cm
Height (Shipping)
66.8 cm
Weight (Shipping)
22 kg
