Take the worry out of always-on recording. Engineered to deliver long-lasting performance, the Samsung PRO Endurance is a great fit for CCTV, dash cams, and body cams. Capture your crucial moments in high-resolution, even in harsh conditions.
                Record and play in Full HD/4KThe PRO Endurance optimizes handling of large video files with read/write speeds up to 100/40 MB/s. Plus, Full HD and 4K resolution support ensures that crucial moments are recorded in immense clarity and detail for the times you need them the most.
                Critical data, protectedFrom severe weather to extensive wear and tear, the PRO Endurance stands up to real-world situations.
- Samsung PRO Endurance MB-MJ32KA - flash memory card - 32 GB - microSDHC UHS-I
- Product Type
- Flash memory card
- Form Factor
- microSDHC UHS-I Memory Card
- Storage Capacity
- 32 GB
- Speed Rating
- Video Class V10 / UHS-I U1 / Class10
- Enclosure Colour
- White
- Included Memory Adapter
- microSDHC to SD adapter
- 2-year warranty
- Product Type
- Flash memory card
- Storage Capacity
- 32 GB
- Enclosure Colour
- White
- Speed Class
- Read Rate
- Up to 100 MB/s
- Write Rate
- Up to 30 MB/s
- Form Factor
- Magnetic-proof, waterproof, X-ray-proof, temperature-proof
- Limited warranty - 2 years
- 15 mm
- 11 mm
- Thickness
- 1 mm
- 0.25 g
- -25 °C
- 85 °C
- 0 - 93%
