Take the worry out of always-on recording. Engineered to deliver long-lasting performance, the Samsung PRO Endurance is a great fit for CCTV, dash cams, and body cams. Capture your crucial moments in high-resolution, even in harsh conditions.
Record and play in Full HD/4K
The PRO Endurance optimizes handling of large video files with read/write speeds up to 100/40 MB/s. Plus, Full HD and 4K resolution support ensures that crucial moments are recorded in immense clarity and detail for the times you need them the most. -
Critical data, protected
From severe weather to extensive wear and tear, the PRO Endurance stands up to real-world situations.
- Samsung PRO Endurance MB-MJ32KA - flash memory card - 32 GB - microSDHC UHS-I
- Product Type
- Flash memory card
- Form Factor
- microSDHC UHS-I Memory Card
- Storage Capacity
- 32 GB
- Speed Rating
- Video Class V10 / UHS-I U1 / Class10
- Enclosure Colour
- White
- Included Memory Adapter
- microSDHC to SD adapter
- 2-year warranty
- Product Type
- Flash memory card
- Storage Capacity
- 32 GB
- Enclosure Colour
- White
- Speed Class
- Read Rate
- Up to 100 MB/s
- Write Rate
- Up to 30 MB/s
- Form Factor
- Magnetic-proof, waterproof, X-ray-proof, temperature-proof
- Limited warranty - 2 years
- 15 mm
- 11 mm
- Thickness
- 1 mm
- 0.25 g
- -25 °C
- 85 °C
- 0 - 93%
