Double up on convenience. The DUO Plus is a Type-C drive with a super-useful Type-A adapter. Eliminate worries as the intuitive integrated Type-A adapter works with your older devices. You can flexibly move data and free up space with superior speed and performance.
Either way is the right way
There's no wrong way to plug it in. Sporting the industry's latest USB Type-C technology, the DUO Plus plugs-in right side up every time - no flipping, no fumbling, no fuss. Transfer large files with ease to your Type-C Smartphones, tablets, PCs and laptops. -
Double your connectivity
One flash drive for many devices. Both USB Type-C and Type-A connectivity, lets you quickly free up device space with fast backups and file offloads. You can add even more movies, music and games. -
Tough & trusted
Files stay secure, anywhere you go. DUO Plus is a trustworthy drive to store your valuable data. It works through it all with a waterproof, shock-proof body.
- Samsung DUO Plus MUF-32DB - USB flash drive - 32 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.1 / USB-C
- Storage Capacity
- 32 GB
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 32 GB
- Read Rate
- Up to 200 MB/s
- Interface Type
- USB 3.1 / USB-C
- Shockproof, magnetic-proof, water resistant, X-ray-proof, temperature-proof
- Limited warranty - 5 years
- 57.92 mm
- 7.29 mm
- 18.33 mm
- 7.7 g
- -25 °C
- 85 °C
