Samsung 32GB Bar Plus USB 3.1 Drive - Titan Grey
Quicklinx: DRNMWS00 Mfr#: MUF-32BE4/EU
Select:
  • 32GB
A modern take on a classic. The next generation Bar Plus elevates the flash drive to an everyday essential, offering impressive speed and striking design. Fit to your hand, the metal unibody is pure minimalism in a drive that cleverly blends style, speed, and reliability.
Get your time back. Fast and convenient read speeds up to 300 MB/s with the USB 3.1 standard give you more time to work, play, watch, and create. Send a 3GB 4K UHD video file from your Bar Plus to your PC in just 10 seconds.
  • Speed in style
  • Move files in a flash
  • Rugged refinement
    As strong as it is stylish. The sturdy metal body keeps your data safe and intact, and the integrated keyring prevents accidental misplacement or loss. The Bar Plus is the ideal combination of stunning design and worry-free durability.
Samsung BAR Plus MUF-32BE4 - USB flash drive - 32 GB
USB flash drive
Interface Type
USB 3.1 Gen 1
Storage Capacity
32 GB
Enclosure Colour
Titan grey
5-year warranty
USB flash drive
Storage Capacity
32 GB
Enclosure Colour
Titan grey
Read Rate
Up to 200 MB/s
Interface Type
USB 3.1 Gen 1
Shockproof, magnetic-proof, waterproof, X-ray-proof, temperature-proof, metal body, key ring loop
Limited warranty - 5 years
15.46 mm
12 mm
40 mm
11.5 g
60 °C
