Samsung 32" UJ590 UHD 4K 3840x2160 2 x HDMI Display Port 4ms
Quicklinx: F223WS00 Mfr#: LU32J590UQUXEN
This monitor delivers more screen space and amazingly life-like images. That means you can view documents and webpages with less scrolling, work more comfortably with multiple windows and toolbars, and enjoy photos, videos and games in stunning quality.
  • Incredibly vivid and realistic images
    This monitor delivers incredibly vivid and realistic images. Its greater accuracy means colors appear more natural and true to life, making it ideal for photo, video and graphics applications.
  • Widescreen gaming
    Discover gaming in true widescreen on this monitor. With millions of pixels supporting a wider range of colors and resolving every image with simply astonishing clarity, gaming becomes a truly thrilling and immersive experience.
  • Smoother gameplay
    Low input lag minimizes the delay between mouse, keyboard, or joystick input and onscreen response for a seamlessly smooth gaming experience. Low input lag is so low that no sooner than when you turn your screen on ,will see the action appear, giving you full control of your game in no time.
  • Game mode
    Game mode instantly optimizes screen contrast to give you a competitive edge during gameplay. By selectively boosting contrast in scenes, game mode reveals more detail in dark areas to let you spot your enemies faster.
Samsung U32J590UQU - LED monitor - 4K - 32"
LED-backlit LCD monitor - 32"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/362980
Energy Class
Class G
Energy Consumption per Year
69 kWh
Power Consumption (On mode)
47 W
Adaptive-Sync Technology
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Brightness
270 cd/m²
Contrast Ratio
3000:1
Response Time
4 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Tilt
Voltage
AC 120/230 V
Dark grey/blue
72.95 cm x 25.05 cm x 53.45 cm
6.3 kg
DisplayPort 1.2
Display Type
Energy Class
Class G
69 kWh
Diagonal Size
32"
Viewable Size
31.5"
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
270 cd/m²
Contrast Ratio
3000:1
Colour Support
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Picture by picture, game mode, Flicker Free technology, Image Size, Eco Saving Plus, Eye Saver Mode, Off Timer Plus, Mega DFC, Picture-in-Picture
Dark grey/blue
72.95 cm x 25.05 cm x 53.45 cm - with stand
6.3 kg
2 x HDMI , DisplayPort , Headphones
Mechanical
Tilt
Tilt Angle
-2/+15
VESA Mounting Interface
100 x 100 mm
HDMI cable
DisplayPort 1.2
Input Voltage
AC 120/230 V
47 W
47 kWh/1000h
Power Consumption (Typical)
59 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Easy Setting Box
Dimensions & Weight Details
With stand - width: 72.95 cm - depth: 25.05 cm - height: 53.45 cm - weight: 6.3 kg , Without stand - width: 72.95 cm - depth: 5.64 cm - height: 42.78 cm - weight: 5.5 kg
Shipping Width
79.2 cm
Shipping Depth
49.1 cm
Shipping Height
15.7 cm
Shipping Weight
8.4 kg
10 °C
10 - 80% (non-condensing)
