Make your own TV
The Frame 32" is a stunningly slim TV that you’ll want to watch even when it’s off. More than just a TV – it’s a glare-free canvas that can be endlessly transformed to showcase the things you love in your home, inspiring you to reinvent your everyday space.
Matte Display
Tired of seeing distracting glare on your TV screen? The Frame's ground-breaking Matte Display overcomes this problem as it absorbs reflections - so even in bright light you'll have the best possible viewing experience. It also helps your TV look just like a picture frame, so you can enjoy beautiful artwork on a glare-free canvas.
Designed to look like a slim picture frame
The Frame 32" is a stunningly slim TV that you'll want to watch even when it's off. This elegantly minimal TV with tidy cables even hangs just like a picture frame, near flush to the wall, so it'll blend beautifully with your home.
                Experience glare-free picture viewingTired of seeing distracting glare on your TV screen? The Frame's ground-breaking Matte Display overcomes this problem as it absorbs reflections - so even in bright light you'll have the best possible viewing experience. It also helps your TV look just like a picture frame, so you can enjoy beautiful artwork on a glare-free canvas.
                Modern frame designThe Frame 32" is a stunningly slim TV that you'll want to watch even when it's off. This elegantly minimal TV with tidy cables even hangs just like a picture frame, near flush to the wall, so it'll blend beautifully with your home.
                TV when it's on, Art when it's offInstead of turning into a black screen, The Frame transforms into a showcase of beautiful artwork and photography when it's turned off, allowing the TV to become part of your décor. Enjoy your favorite pieces for as long and as often as you like with no screen burn worries - guaranteed.
                Senses your presenceWhen you're in the room, the Motion Sensor detects your presence and automatically turns the TV to Art mode, So you can enjoy art while you're there. When you leave, it turns off into standby mode to save energy.
                The ideal way to appreciate art, in any lightThe Brightness Sensor detects ambient light and automatically adjusts the screen's brightness and color tone to perfectly match the art piece on display.
                Naturally bright and colorful pictureSee everything you watch come to life with greater detail and realism. Samsung's Quantum Dot powered TVs transform light into lifelike and accurate color - validated by Pantone. The result? A naturally bright and colorful picture in over a billion cinematic colors.
                Sound that tracks the action on- screenObject Tracking Sound Lite chooses which of the TV's front speakers the sound comes through depending on where the action is happening on screen. So you can hear a car fly along your screen or the crowd cheering all around you.
- Samsung QE32LS03CBU The Frame LS03C Series - 32" LED-backlit LCD TV - QLED - Full HD
- Product Type
- LED-backlit LCD TV - QLED - Smart TV
- Diagonal Class
- 32"
- Black
- Platform
- Tizen OS
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- HDR Format
- HDR10+
- HDR Technology
- Hybrid Log-Gamma (HLG)
- Frame Rate & Enhancement Technology
- 50 Hz Refresh Rate, Motion Xcelerator
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- Wi-Fi, Bluetooth
- LCD Backlight Technology
- LED backlight - Quantum Dot technology Micro Dimming Pro
- Image Aspect Ratio
- 16:9
- TV Tuner
- 1x analogue, 1x digital
- Digital TV Tuner
- DVB-C, DVB-S2, DVB-T2
- Internet Streaming Services
- Smart Hub, Samsung TV PLUS
- Picture Enhancements
- HyperReal Engine, Mega Contrast, contrast enhancer, 100% Color Volume, One Billion Colour, Picture Clarity
- Speaker System
- 2 channel
- Platform
- SmartThings
- Intelligent Assistant
- Google Assistant, Alexa, Bixby (not available for some languages and countries)
- USB
- 2 ports
- Included Accessories
- Samsung TM2361E remote control
- Voltage
- AC 220-240 V (50/60 Hz)
- Energy Class
- Class F
- 27.4 Watt
- Power Consumption Stand by
- 0.5 Watt
- Dimensions (WxDxH) - without stand
- 72.73 cm x 2.55 cm x 42.68 cm
- 5.1 kg
- 1-year warranty
- Product Type
- Energy Class
- Class F
- Energy Class (HDR)
- Class G
- Power Consumption (Max)
- 55 Watt
- 27.4 Watt
- Power Consumption SDR (On mode)
- 27 kWh/1000h
- Power Consumption HDR (On mode)
- 49 kWh/1000h
- Diagonal Class
- 32"
- Series
- The Frame LS03C Series
- Model Year
- 2023
- Platform
- Tizen OS
- Operating System
- Tizen OS
- HDR Capable
- HDR Format
- HDR10+
- HDR Technology
- TV Tuner
- TV Tuner Presence
- Sensors
- Eco Sensor, motion sensor
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- Modes
- Film Mode, Art Mode, power saving mode, HGIG Mode
- Design
- Very Narrow Bezel Design (VNB), Modern Frame Design
- Dimensions
- Without stand
- 72.73 cm
- 2.55 cm
- 42.68 cm
- 5.1 kg
- Enclosure Colour
- Black
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight - Quantum Dot technology - Micro Dimming Pro
- Coating
- Anti-reflection
- Display Menu Language
- Multilingual
- Smart Calibration, One Connect Box, Customizable Frame, Motion Detection, Brightness/Colour Detection, Samsung Health, Wireless Dex, Microsoft 365 Cloud, Gaming Hub, SlimFit Cam support
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Stand Colour
- Black
- Flat Panel Mount Interface
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
Video Features
- Teletext
- Electronic Programme Guide
- Digital EPG
Media Player
- USB Port
- USB Ports Qty
- 2
Remote Control
- Remote control
- Remote Control Model
- Samsung TM2361E
- SolarCell remote
Audio System
- Speaker System
- 2 channel
- Output Power / Total
- 20 Watt
- Bluetooth Audio Streaming, Audio Return Channel (ARC), Audio Pre-selection Descriptor, Adaptive Sound, Q-Symphony, Object Tracking Sound Lite, Dual Audio support, Buds Auto Switch
Network & Internet Multimedia
- Functionality
- WEB browsing, Internet video playback
- Connectivity
- Wi-Fi, Bluetooth
- Wi-Fi Protocol
- 802.11ac
- Bluetooth Version
- Bluetooth 5.2
- Connect & Share
- Screen Mirroring, ConnectShare, Sound Mirroring, Tap View, Media Home
- Supported Consumer Electronics Control (CEC)
- Anynet Plus, Multiroom Link
- Application Store
- Art Store
- Connector Type
- 2 x HDMI , 2 x USB , Digital audio output (optical) , One Connect Mini
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Platform
- SmartThings
- CEC, HGiG, IPv6
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Auto On/Off
- Limited warranty - 1 year
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 72.73 cm x 2.55 cm x 42.68 cm x 5.1 kg , Panel with stand - 72.73 cm x 14.33 cm x 45.19 cm x 5.2 kg , Stand - 59.12 cm x 14.33 cm
- Width (Shipping)
- 81.5 cm
- Depth (Shipping)
- 11.9 cm
- Height (Shipping)
- 50.7 cm
- Weight (Shipping)
- 7.8 kg
