Samsung 32" S80PB Monitor
Quicklinx: HR24WS00 Mfr#: LS32B800PXUXXU
Diagonal Size: 32in
Max Resolution: 3840 x 2160
Response Time: 5ms
Speakers: None
Interfaces: DisplayPort, HDMI, USB-C
£546.87 ex VAT
£656.24 inc VAT
Samsung's ViewFinity delivers innovative experiences that can unlock the potential of business professionals, content creators, and even graphic designers, with technology that brings any vision to life like never seen before.
Uncover every detail with maximum clarity. With 4x the pixels of Full HD, every detail is viewed in enhanced depth, while more screen real estate provides space to view multiple tools, applications and programs. Plus, IPS panel delivers crystal clear color quality and a wide viewing angle of 178°.
Showcase more colors for greater impact. S8 features an extended color range supporting up to 98% of DCI-P3, creating richer and more vibrant colors in every project. With pro-level precision, graphic designers and other creatives can deliver full accuracy without compromise.
  • Samsung ViewFinity, a benchmark for high resolution
  • Deeper details for creative clarity
  • Pro-level color expression
  • Realize richer, more refined shades
    Show more with every shade. HDR support brings a true high dynamic range of luminous blacks and whites to the screen. Dark areas are richer and more profound, while bright parts are even more dazzling and intense, delivering clear and detailed resolution for an outstanding viewing experience.
  • Clear even during the day
    Edit and review content clearly even in bright daylight. With the adcanced glare-free monitor verified by UL, the Matte Display technology enables professionals to review and edit with consistent levels of brightness and colors even without a monitor hood.
  • An ultimate hub for versatile use
    Ditch the clutter and keep connected. Power your laptop and transmit data with just one USB Type-C cable with 90 W charging for less connection mess in your workspace. The additional LAN port allows a laptop without a port to simply connect to the monitor for Ethernet use.
  • Relieve your eyes from strain
    Keep your eyes fresh and strain-free. For those late-night projects, brightness and color temperature adjust automatically for optimization in any environment. TUV-certified for intelligent eye care, Samsung protects eyes against excessive blue light with eye saver mode and a flicker free feature.
  • Make room for more tasks
    Double up on the ways you work, chat and play. With PBP, view input from two simultaneous sources at native resolution, allowing you to review two projects or run two programs. Use PIP to resize a second source to up to 25% of the screen, allowing you to work on one task while monitoring another.
  • Maximize comfort, minimize distractions
    Find a monitor position that maximizes your comfort. Pivot the screen from portrait to landscape or adjust up and down for the perfect height. Then tilt and swivel to capture the best viewing angle. The slim metal stand with narrow depth takes up less desk space for a clean, seamless work setup.
Samsung S32B800PXU - S80PB Series - LED monitor - 4K - 32" - HDR
LED-backlit LCD monitor - 32"
Energy Class
Class G
Energy Consumption per Year
48 kWh
USB 3.0/USB-C hub, Ethernet network adapter, USB PD 90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Brightness
350 cd/m²
Contrast Ratio
1000:1
HDR Capable
DisplayHDR 600
Response Time
5 ms
Colour Support
1.07 billion colours
Colour Gamut
98% DCI-P3
Input Connectors
HDMI, DisplayPort, USB-C
Built-in Ethernet
Display Position Adjustments
Screen Coating
Anti-glare, matte
Voltage
AC 100-240 V
71.61 cm x 21.14 cm x 58.04 cm
7.5 kg
Environmental Standards
TCO Certified Displays 9, TCO Certified, generation 10, for displays, ENERGY STAR Qualified
UL, TUV, FSC
Display Type
Energy Class
Class G
Energy Class (HDR)
Class G
48 kWh
Diagonal Size
32"
Built-in Devices
USB Power Delivery
90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
350 cd/m²
Contrast Ratio
1000:1
HDR Certification
DisplayHDR 600
Colour Support
Colour Gamut
98% DCI-P3
Response Time
5 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare, matte
Backlight Technology
LED backlight
HighBrightness, picture by picture, game mode, Cinema Mode, Mega Dynamic Contrast Ratio, Eco Light Sensor, CustomColor Mode, Flicker Free technology, Image Size, DICOM Simulation, Eco Saving Plus, Eye Saver Mode, Factory Tunning, Factory Calibration Report, Off Timer Plus, Wide Viewing Angle, sRGB Mode, Picture-in-Picture, Dynamic Contrast Mode, Auto Source Switch+, Adaptive Picture, Eco Sensor
71.61 cm x 21.14 cm x 58.04 cm - with stand
7.5 kg
DisplayPort 1.4 , HDMI , 3 x USB 3.0 , USB-C (power up to 90W) , Headphones , LAN
Mechanical
Tilt Angle
-2/+25
Swivel Angle
60
Rotation Angle
-2/+92
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable , 1 x USB-C cable
UL, TUV, FSC
Security Slot Type
Kensington security slot
Input Voltage
AC 100-240 V
33 kWh/1000h
Power Consumption HDR (On mode)
71 kWh/1000h
Power Consumption (Typical)
33 Watt
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
With stand - width: 71.61 cm - depth: 21.14 cm - height: 58.04 cm - weight: 7.5 kg , Without stand - width: 71.61 cm - depth: 4.13 cm - height: 42.47 cm - weight: 5.2 kg
Shipping Width
80 cm
Shipping Depth
17.1 cm
Shipping Height
51.1 cm
Shipping Weight
9.5 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
10 °C
10 - 80% (non-condensing)
Diagonal Size: 32in
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Interfaces: USB-C
Brand: Samsung
Price Range Ex VAT: £500 - £750
