Samsung's ViewFinity delivers innovative experiences that can unlock the potential of business professionals, content creators, and even graphic designers, with technology that brings any vision to life like never seen before.
Uncover every detail with maximum clarity. With 4x the pixels of Full HD, every detail is viewed in enhanced depth, while more screen real estate provides space to view multiple tools, applications and programs. Plus, IPS panel delivers crystal clear color quality and a wide viewing angle of 178°.
Showcase more colors for greater impact. S8 features an extended color range supporting up to 98% of DCI-P3, creating richer and more vibrant colors in every project. With pro-level precision, graphic designers and other creatives can deliver full accuracy without compromise.
Samsung ViewFinity, a benchmark for high resolution
Samsung's ViewFinity delivers innovative experiences that can unlock the potential of business professionals, content creators, and even graphic designers, with technology that brings any vision to life like never seen before. -
Deeper details for creative clarity
Uncover every detail with maximum clarity. With 4x the pixels of Full HD, every detail is viewed in enhanced depth, while more screen real estate provides space to view multiple tools, applications and programs. Plus, IPS panel delivers crystal clear color quality and a wide viewing angle of 178°. -
Pro-level color expression
Showcase more colors for greater impact. S8 features an extended color range supporting up to 98% of DCI-P3, creating richer and more vibrant colors in every project. With pro-level precision, graphic designers and other creatives can deliver full accuracy without compromise. -
Realize richer, more refined shades
Show more with every shade. HDR support brings a true high dynamic range of luminous blacks and whites to the screen. Dark areas are richer and more profound, while bright parts are even more dazzling and intense, delivering clear and detailed resolution for an outstanding viewing experience. -
Clear even during the day
Edit and review content clearly even in bright daylight. With the adcanced glare-free monitor verified by UL, the Matte Display technology enables professionals to review and edit with consistent levels of brightness and colors even without a monitor hood. -
An ultimate hub for versatile use
Ditch the clutter and keep connected. Power your laptop and transmit data with just one USB Type-C cable with 90 W charging for less connection mess in your workspace. The additional LAN port allows a laptop without a port to simply connect to the monitor for Ethernet use. -
Relieve your eyes from strain
Keep your eyes fresh and strain-free. For those late-night projects, brightness and color temperature adjust automatically for optimization in any environment. TUV-certified for intelligent eye care, Samsung protects eyes against excessive blue light with eye saver mode and a flicker free feature. -
Make room for more tasks
Double up on the ways you work, chat and play. With PBP, view input from two simultaneous sources at native resolution, allowing you to review two projects or run two programs. Use PIP to resize a second source to up to 25% of the screen, allowing you to work on one task while monitoring another. -
Maximize comfort, minimize distractions
Find a monitor position that maximizes your comfort. Pivot the screen from portrait to landscape or adjust up and down for the perfect height. Then tilt and swivel to capture the best viewing angle. The slim metal stand with narrow depth takes up less desk space for a clean, seamless work setup.
 - Samsung S32B800PXU - S80PB Series - LED monitor - 4K - 32" - HDR
 - LED-backlit LCD monitor - 32"
- Energy Class
 - Class G
- Energy Consumption per Year
 - 48 kWh
 - USB 3.0/USB-C hub, Ethernet network adapter, USB PD 90 Watt
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
 - 4K 3840 x 2160 at 60 Hz
- Brightness
 - 350 cd/m²
- Contrast Ratio
 - 1000:1
- HDR Capable
 - DisplayHDR 600
- Response Time
 - 5 ms
- Colour Support
 - 1.07 billion colours
- Colour Gamut
 - 98% DCI-P3
- Input Connectors
 - HDMI, DisplayPort, USB-C
- Built-in Ethernet
 - Height, pivot (rotation), swivel, tilt
- Screen Coating
 - Anti-glare, matte
- Voltage
 - AC 100-240 V
 - Black
 - 71.61 cm x 21.14 cm x 58.04 cm
 - 7.5 kg
- Environmental Standards
 - TCO Certified Displays 9, TCO Certified, generation 10, for displays, ENERGY STAR Qualified
 - UL, TUV, FSC
- Display Type
- Energy Class
 - Class G
- Energy Class (HDR)
 - Class G
 - 48 kWh
- Diagonal Size
 - 32"
- Built-in Devices
- USB Power Delivery
 - 90 Watt
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
- Brightness
 - 350 cd/m²
- Contrast Ratio
 - 1000:1
- HDR Certification
 - DisplayHDR 600
- Colour Support
- Colour Gamut
 - 98% DCI-P3
- Response Time
 - 5 ms
- Horizontal Viewing Angle
 - 178
- Vertical Viewing Angle
 - 178
- Screen Coating
 - Anti-glare, matte
- Backlight Technology
 - LED backlight
 - HighBrightness, picture by picture, game mode, Cinema Mode, Mega Dynamic Contrast Ratio, Eco Light Sensor, CustomColor Mode, Flicker Free technology, Image Size, DICOM Simulation, Eco Saving Plus, Eye Saver Mode, Factory Tunning, Factory Calibration Report, Off Timer Plus, Wide Viewing Angle, sRGB Mode, Picture-in-Picture, Dynamic Contrast Mode, Auto Source Switch+, Adaptive Picture, Eco Sensor
 - Black
 - 71.61 cm x 21.14 cm x 58.04 cm - with stand
 - 7.5 kg
 - DisplayPort 1.4 , HDMI , 3 x USB 3.0 , USB-C (power up to 90W) , Headphones , LAN
Mechanical
- Tilt Angle
 - -2/+25
- Swivel Angle
 - 60
- Rotation Angle
 - -2/+92
- Height Adjustment
 - 120 mm
- VESA Mounting Interface
 - 100 x 100 mm
- Cables Included
 - 1 x HDMI cable , 1 x USB-C cable
 - UL, TUV, FSC
- Security Slot Type
 - Kensington security slot
- Input Voltage
 - AC 100-240 V
- Power Consumption SDR (On mode)
 - 33 kWh/1000h
- Power Consumption HDR (On mode)
 - 71 kWh/1000h
- Power Consumption (Typical)
 - 33 Watt
- Power Consumption Stand by
 - 0.5 Watt
- Dimensions & Weight Details
 - With stand - width: 71.61 cm - depth: 21.14 cm - height: 58.04 cm - weight: 7.5 kg , Without stand - width: 71.61 cm - depth: 4.13 cm - height: 42.47 cm - weight: 5.2 kg
- Shipping Width
 - 80 cm
- Shipping Depth
 - 17.1 cm
- Shipping Height
 - 51.1 cm
- Shipping Weight
 - 9.5 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
 - 10 °C
 - 40 °C
 - 10 - 80% (non-condensing)
