- Samsung S32BM801UU - M80B Series - LED monitor - 4K - 32" - HDR
- LED-backlit LCD monitor - 32" - Smart monitor
- Energy Class
- Class G
- Energy Consumption per Year
- 58 kWh
- USB Hub, 802.11a/b/g/n/ac network adapter, Bluetooth 4.2 adapter, USB PD 65 Watt
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160 at 60 Hz
- Brightness
- 400 cd/m²
- Contrast Ratio
- 3000:1
- HDR Capable
- HDR10, HDR10+
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 1 billion colours
- Colour Gamut
- 99% sRGB
- Input Connectors
- Micro HDMI, USB-C
- Height, tilt
- Voltage
- AC 100-240 V (50/60 Hz)
- Warm white
- 71.34 cm x 20.38 cm x 57.52 cm
- 6.7 kg
- CEC
- 3-year warranty
- Display Type
- LED-backlit LCD monitor / TFT active matrix - Smart monitor
- Energy Class
- Class G
- Energy Class (HDR)
- Class G
- 58 kWh
- Diagonal Size
- 32"
- Built-in Devices
- USB Power Delivery
- 65 Watt
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 400 cd/m²
- Contrast Ratio
- 3000:1
- HDR Format
- HDR10, HDR10+
- Colour Support
- 1 billion colours
- Colour Gamut
- 99% sRGB
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Game mode, ConnectShare, Flicker Free technology, Eye Saver Mode, Factory Tunning, DLNA, Auto Source Switch+, Adaptive Picture, Ultrawide Game View, Tizen Platform, Tap View, Remote Access, Sound Mirroring, SmartThings App Support, Game Bar 2.0, Adaptive Sound+, far-field voice interaction
- Warm white
- 71.34 cm x 20.38 cm x 57.52 cm - with stand
- 6.7 kg
Audio
- Speakers
- Micro HDMI (HDCP 2.0) , USB-C 3.0 (power up to 65W)
Mechanical
- Height, tilt
- Tilt Angle
- -2/+15
- Height Adjustment
- 120 mm
- Security lock slot (cable lock sold separately), Bixby Voice Assistant
- Included Accessories
- Remote control
- Cables Included
- 1 x micro-HDMI-HDMI cable , 1 x USB-C cable
- CEC
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption SDR (On mode)
- 40 kWh/1000h
- Power Consumption HDR (On mode)
- 75 kWh/1000h
- Power Consumption (Typical)
- 40 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- Microsoft 365, Alexa, Google Assistant, SmartThings, Samsung TV Plus, Google Duo
- OS Required
- Tizen OS, Windows 10
- Dimensions & Weight Details
- With stand - width: 71.34 cm - depth: 20.38 cm - height: 57.52 cm - weight: 6.7 kg , Without stand - width: 71.34 cm - depth: 2.23 cm - height: 41.88 cm - weight: 4.4 kg
- Shipping Width
- 79.8 cm
- Shipping Depth
- 12.4 cm
- Shipping Height
- 56.8 cm
- Shipping Weight
- 9.4 kg
- Limited warranty - 3 years
- 10 °C
- 40 °C
- 10 - 80% (non-condensing)
