Watch, Play, Work in Style
A Monitor & Streaming TV All in One
Smart TV Apps
Have to make the most out of a small space, or simply want a second TV? The Smart Monitor is the best choice. Stream OTT content directly from the monitor, or tune into Samsung TV Plus to get live TV channels and on-demand content at zero cost.
4K UHD
Crystal clear video. 4K UHD resolution brings your content to life as intended, making worlds feel more real with vivid clarity. Lose yourself while exploring nuanced settings with incredible detail.
Multiple Ports
With USB-C, HDMI and USB-A ports, you can connect completely to the Smart Monitor without any adapters. Charge your devices, transmit data and make the most out of your multi-screen setup _ or do all at once _ thanks to the six available ports.
Immersive display
Experience clarity and color with the 32-inch 4K UHD monitor, boasting a 3000:1 contrast ratio and HDR10 support for vibrant, lifelike images. -
Seamless connectivity
Equipped with HDMI and USB-C interfaces, this monitor serves as a hub for all your devices, offering easy connection and charging capabilities with USB Power Delivery up to 65 W. -
Advanced audiovisual features
Enhance your viewing and gaming experience with Adaptive Picture, Adaptive Sound, and Super Ultrawide GameView, ensuring optimal brightness, sound, and field of view. -
Smart capabilities
Transform your monitor into an entertainment center with Smart TV features, Gaming Hub, and IoT Hub, powered by Tizen OS for a seamless smart experience. -
Ergonomic design
Adjust the monitor to your comfort with tilt adjustments ranging from -2 to +22 degrees, complemented by a flat front bezel for a sleek, modern look.
- Samsung S32DM700UU - M70D Series - LED monitor - 4K - 32" - HDR
- LED-backlit LCD monitor - 32" - Smart monitor
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/1956448
- Energy Class
- Class F
- Energy Consumption per Year
- 47 kWh
- Wi-Fi, USB 2.0/USB-C hub, Bluetooth 5.2 adapter, USB PD 65 Watt
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160 at 60 Hz
- Pixel Pitch
- 0.1845 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1
- HDR Capable
- HDR10
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 1 billion colours
- Colour Gamut
- 72% NTSC (CIE 1976)
- Input Connectors
- 2xHDMI, USB-C
- Tilt
- Voltage
- AC 100-240 V
- Black
- 71.61 cm x 19.35 cm x 51.7 cm
- 6.5 kg
- CEC, HDCP 2.2
- Display Type
- LED-backlit LCD monitor / TFT active matrix - Smart monitor
- Energy Class
- Class F
- Energy Class (HDR)
- Class G
- 47 kWh
- Diagonal Size
- 32"
- Operating System
- Tizen
- Built-in Devices
- USB Power Delivery
- 65 Watt
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.1845 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1
- HDR Format
- HDR10
- Colour Support
- 1 billion colours
- Colour Gamut
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- MultiView, Smart TV, Flicker Free technology, Image Size, Eye Saver Mode, Factory Tunning, Auto Source Switch+, Adaptive Picture, Ultrawide Game View, Tap View, Sound Mirroring, Adaptive Sound, Game Bar 2.0, far-field voice interaction, Virtual AIM Point, IoT Hub, Gaming Hub, Nifty Gateway, My Contents, Smart Calibration
- Black
- 71.61 cm x 19.35 cm x 51.7 cm - with stand
- 6.5 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 5 Watt
- 2 x HDMI (HDCP 2.2) , USB-C (power up to 65W) , 3 x USB 2.0
Mechanical
- Tilt
- Tilt Angle
- -2/+22
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), screen mirroring
- Included Accessories
- SolarCell remote control
- Cables Included
- 1 x HDMI cable
- CEC, HDCP 2.2
- Security Slot Type
- Kensington security slot
- Input Voltage
- AC 100-240 V
- Power Consumption SDR (On mode)
- 32 kWh/1000h
- Power Consumption HDR (On mode)
- 58 kWh/1000h
- Power Consumption (Typical)
- 32 Watt
- Power Consumption (Max)
- 150 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- Intel Wireless Display, Apple AirPlay, Microsoft 365, Alexa, SmartThings, Samsung TV Plus, Bixby Voice Assistant
- Dimensions & Weight Details
- With stand - width: 71.61 cm - depth: 19.35 cm - height: 51.7 cm - weight: 6.5 kg , Without stand - width: 71.61 cm - depth: 4.18 cm - height: 42.45 cm - weight: 5.4 kg
- Shipping Width
- 84.2 cm
- Shipping Depth
- 48.7 cm
- Shipping Height
- 13.3 cm
- Shipping Weight
- 7.9 kg
- 10 °C
- 40 °C
- 10 - 80% (non-condensing)
