Samsung 32" M70B UHD, USB-C Smart Monitor with Speakers & Re
Quicklinx: HTTMWS00 Mfr#: LS32DM700UUXXU
Diagonal Size: 32in
Max Resolution: 3840 x 2160
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: USB-C, HDMI
£291.66 ex VAT
£349.99 inc VAT
Express delivery Delivered on Wednesday
Watch, Play, Work in Style
A Monitor & Streaming TV All in One
Smart TV Apps
Have to make the most out of a small space, or simply want a second TV? The Smart Monitor is the best choice. Stream OTT content directly from the monitor, or tune into Samsung TV Plus to get live TV channels and on-demand content at zero cost.
4K UHD
Crystal clear video. 4K UHD resolution brings your content to life as intended, making worlds feel more real with vivid clarity. Lose yourself while exploring nuanced settings with incredible detail.
Multiple Ports
With USB-C, HDMI and USB-A ports, you can connect completely to the Smart Monitor without any adapters. Charge your devices, transmit data and make the most out of your multi-screen setup _ or do all at once _ thanks to the six available ports.
  • Immersive display
    Experience clarity and color with the 32-inch 4K UHD monitor, boasting a 3000:1 contrast ratio and HDR10 support for vibrant, lifelike images.
  • Seamless connectivity
    Equipped with HDMI and USB-C interfaces, this monitor serves as a hub for all your devices, offering easy connection and charging capabilities with USB Power Delivery up to 65 W.
  • Advanced audiovisual features
    Enhance your viewing and gaming experience with Adaptive Picture, Adaptive Sound, and Super Ultrawide GameView, ensuring optimal brightness, sound, and field of view.
  • Smart capabilities
    Transform your monitor into an entertainment center with Smart TV features, Gaming Hub, and IoT Hub, powered by Tizen OS for a seamless smart experience.
  • Ergonomic design
    Adjust the monitor to your comfort with tilt adjustments ranging from -2 to +22 degrees, complemented by a flat front bezel for a sleek, modern look.
Samsung S32DM700UU - M70D Series - LED monitor - 4K - 32" - HDR
LED-backlit LCD monitor - 32" - Smart monitor
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/1956448
Energy Class
Class F
Energy Consumption per Year
47 kWh
Wi-Fi, Bluetooth 5.2 adapter, USB 2.0/USB-C hub, USB PD 65 Watt
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.1845 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1
HDR Capable
HDR10
Response Time
4 ms (grey-to-grey)
Colour Support
1 billion colours
Colour Gamut
72% NTSC (CIE 1976)
Input Connectors
2xHDMI, USB-C
Display Position Adjustments
Tilt
Voltage
AC 100-240 V
71.61 cm x 19.35 cm x 51.7 cm
6.5 kg
CEC, HDCP 2.2
Display Type
LED-backlit LCD monitor / TFT active matrix - Smart monitor
Energy Class
Class F
Energy Class (HDR)
Class G
47 kWh
Diagonal Size
32"
Operating System
Tizen
Built-in Devices
USB Power Delivery
65 Watt
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1845 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1
HDR Format
HDR10
Colour Support
1 billion colours
Colour Gamut
72% NTSC (CIE 1976)
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Eye Saver Mode, Flicker Free technology, Image Size, Virtual AIM Point, Game Bar 2.0, Gaming Hub, Auto Source Switch+, Adaptive Picture, Ultrawide Game View, far-field voice interaction, My Contents, MultiView, Smart Calibration, Nifty Gateway, Tap View, Adaptive Sound, Sound Mirroring, Smart TV, IoT Hub, Factory Tunning
71.61 cm x 19.35 cm x 51.7 cm - with stand
6.5 kg
Audio
Speakers - stereo
Output Power / Channel
5 Watt
2 x HDMI (HDCP 2.2) , USB-C (power up to 65W) , 3 x USB 2.0
Mechanical
Tilt
Tilt Angle
-2/+22
VESA Mounting Interface
100 x 100 mm
Screen mirroring, security lock slot (cable lock sold separately)
SolarCell remote control
1 x HDMI cable
CEC, HDCP 2.2
Security Slot Type
Kensington security slot
Input Voltage
AC 100-240 V
32 kWh/1000h
Power Consumption HDR (On mode)
58 kWh/1000h
Power Consumption (Typical)
32 Watt
Power Consumption (Max)
150 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Bixby Voice Assistant, Samsung TV Plus, Alexa, SmartThings, Intel Wireless Display, Microsoft 365, Apple AirPlay
Dimensions & Weight Details
With stand - width: 71.61 cm - depth: 19.35 cm - height: 51.7 cm - weight: 6.5 kg , Without stand - width: 71.61 cm - depth: 4.18 cm - height: 42.45 cm - weight: 5.4 kg
Shipping Width
84.2 cm
Shipping Depth
48.7 cm
Shipping Height
13.3 cm
Shipping Weight
7.9 kg
10 °C
10 - 80% (non-condensing)
Diagonal Size: 32in
Response Time: 4ms
Interfaces: USB-C
Interfaces: HDMI
Brand: Samsung
