Samsung 32" LED TV Smart WiFi - UE32F5500
TOP SPEC 2013 MODEL - FULL HD !
Quicklinx: 8NCYWS00 Mfr#: UE32F5500AKXXU
  • 1080p
Now it's even easier to discover and enjoy all kinds of great entertainment. With a Samsung F5500 Series 5 LED TV, you can enjoy tailored recommendations based upon your tastes from S Recommendation. Samsung's Smart Hub gives you access to a wide range of online apps and content, including movies and TV programmes on demand. Thanks to a powerful Dual Core processor, you can also take advantage of fast multitasking, so you can browse the web smoothly, download one app while using another, and more.
An entertainment experience tailored to you
Choosing the right channel or finding the right movie doesn't have to be difficult; it should be easy. By understanding your entertainment preferences and viewing habits, S Recommendation intuitively recommends content for you to enjoy. Waste no more time searching through the same TV line up or movies over and over, and watch shows that best appeal to you. The more you watch, the more the Smart TV understands you - there will always be something entertaining to watch.
The gateway to a revolutionary entertainment experience
Samsung is changing the rules of watching TV with Smart Hub. With 5 advanced and easy-to use panels and an intuitive Smart Hub UI flipping motion, Smart Hub allows you to search and access content quickly and easily. With immediate access to live TV recommendations, watch everything you enjoy without having to channel surf. Enjoy a wide range of movie and TV shows with videos on demand, access apps available on the Samsung Smart TV and share content on Facebook and Twitter with friends. Enjoy and access photos, videos, and music on all compatible devices.
  • Screen image picture is a representation and may not reflect actual user interface.
  • Content, TV services and capabilities may not be available in all regions and territories.
Dual Core makes multitasking fast
Dual Core's faster processing speeds allow you to perform multiple tasks at the same time, such as using an app while downloading another one. It also enables faster web browsing while playing apps or TV programs that you've recently opened through the Recent History feature.
Filtering noise for added TV viewing pleasure
Experience crystal-clear TV viewing with Samsung's Clean View. When Clean View's auto noise-removal technology is applied, it removes digital noise that is seen on the screen, enhancing the picture quality. Sit back, relax and watch TV with the best clarity.
Designed for maximum appeal
Samsung's One Design maximises the viewing experience as well as enhances your home interior. One Design elegantly combines the LED TV's Ultra-slim bezel with its panel to remove any barriers from a seamless viewing experience.
Watch movies from your USB
With ConnectShare Movie, simply plug your USB memory drive or HDD into the TV and instantaneously enjoy movies, photos or music. Now, you can experience a wide variety of content in the comfort of your living room on your TV.
Discover a new reality in Full HD
Enjoy a greater level of home entertainment realism than ever before. Thanks to a resolution twice as high as standard HD TVs, your Samsung Smart TV delivers a breathtaking viewing experience that takes you beyond the screen into a world of total immersion. When you've seen the rich and vivid texture of Full HD images, your favourite TV programs and movies will never be the same again. Discover reality with a full high definition experience.
More vibrant colours for better images
Using an advanced picture quality improvement algorithm, Samsung's Wide Colour Enhancer Plus drastically improves the quality of any image and uncovers hidden details. Now see colours as they were meant to be seen with Wide Colour Enhancer Plus.
Stay connected by sharing
Seamlessly share content across all of your connected devices with Samsung's AllShare. AllShare allows you to share photos, videos and music from your Samsung compatible smartphone, tablet, laptop and camera to the big screen of your TV. Now enjoy your content on Smart TV with as little fuss as possible.
Samsung UE32F5500 5 Series - 32" LED-backlit LCD TV - Full HD
LED-backlit LCD TV - Smart TV
Diagonal Class
32"
Resolution
1920 x 1080
Display Format
1080p
Frame Rate & Enhancement Technology
100 Clear Motion Rate
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
3 ports
Wi-Fi, LAN
HDCP Compatible
LCD Backlight Technology
LED backlight
TV Tuner
1x analogue, 1x digital
Digital TV Tuner
DVB-C, DVB-T2
Internet Streaming Services
Smart Hub
Multi-channel Preview
Picture-in-picture (PIP)
Speaker System
2 speakers
Sound Effects
DTS Studio Sound, DTS Premium Audio 5.1
USB
2 ports
Samsung TM1250A remote control
Voltage
AC 230V (50/60 Hz)
Energy Class
Class A
Power Consumption (On mode)
40 W
Power Consumption Stand by
0.3 Watt
Energy Consumption per Year
58 kWh
73.82 cm x 26.5 cm x 50.96 cm
6.1 kg
1-year warranty
Energy Class
Class A
40 W
58 kWh
Diagonal Class
32"
Series
5 Series
TV Tuner
TV Tuner Presence
Extended PVR
Sensors
Eco Sensor
Video Interface
HDMI Ports Qty
3 ports
HDCP Compatible
Modes
Game mode
Timer Functions
Sleep, wake
Design
One Design
Dimensions
With stand
73.82 cm
26.5 cm
50.96 cm
6.1 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p
LED backlight
Time-shift, HyperReal Engine, Wide Color Enhancer Plus, Social TV, Online Instruction Manual, Fitness, Kids Story, Digital Clean View
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Stand Features
Swivel
Flat Panel Mount Interface
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
DVB-C, DVB-T2
HDTV Tuner
Video Features
Teletext
Electronic Programme Guide
Digital EPG
Closed Caption Capability
Media Player
USB Port
USB Ports Qty
2
Remote Control
Remote control
Remote Control Model
Samsung TM1250A
Smart phone remote support
Audio System
Digital Audio Format
DTS digital output, Dolby Digital Plus output, Dolby Pulse output
Surround Mode
Sound Effects
Speaker System
2 speakers
Output Power / Total
20 Watt
Auto volume adjustment, Down-firing Speaker, Smart View
Speakers
2 x main channel speaker - 10 Watt
Driver Details
Main channel speaker: 1 x full-range driver
Network & Internet Multimedia
Functionality
Digital audio playback, digital photo playback, digital video playback, WEB browsing, Internet video playback
Wi-Fi, LAN
LAN Protocol
Ethernet
Connect & Share
Wi-Fi Direct, ConnectShare Movie, AllShare
Smart Hub
Supported Consumer Electronics Control (CEC)
Anynet Plus
Application Store
Samsung Apps
Connector Type
3 x HDMI , 2 x USB 2.0 , Composite video / component video input , Headphones , Digital audio output (optical) , SCART , Audio input , LAN
Power supply
Input Voltage
AC 230V (50/60 Hz)
0.3 Watt
Auto On/Off
Limited warranty - parts and labour - 1 year - carry-in
Dimensions & Weight Details
Panel with stand - 73.82 cm x 26.5 cm x 50.96 cm x 6.1 kg , Panel without stand - 73.82 cm x 4.9 cm x 44.54 cm x 5 kg
Width (Shipping)
98.5 cm
Depth (Shipping)
14.3 cm
Height (Shipping)
59.6 cm
Weight (Shipping)
8.1 kg
