Samsung 32" K4100 4 Series Joiiii HD TV
Quicklinx: C1XDWS00 Mfr#: UE32K4100AKXXU
Your space. Your unique lifestyle. Joiiii
Enjoy crisp and clear 100 PQI HD content with vibrant images delivered through Wide Colour Enhancer technology. Digital Clean View technology analyses the quality of the signal input, improving your viewing experience and delivering superior picture quality.
HD Ready
Joiiii Design
The unique Joiiii design is sophisticated and elegant with adjustable legs, making it adaptable to fit anywhere in the home. You can also enjoy crisp and clear sound from the unique front firing speaker and tweeters. Your TV has never sounded so good.
Using an advanced picture quality improvement algorithm, Samsung's Wide Colour Enhancer drastically improves the quality of any image, uncovering hidden details and allowing you to see colours as they were meant to be seen.
Create your own entertainment space
Samsung TVs support HDMI inputs, which lets you create a multimedia entertainment centre in your own living room. Connect HDMI straight into your TV to view various contents from multiple devices.
What's In The Box?
  • Manual/ Quick Guide
  • Power Cable
  • Remote Control
  • Batteries (AAA x2)
  • HD ready
    Enjoy crisp and clear 100 PQI HD content with vibrant images delivered through Wide Color Enhancer technology. Digital Clean View technology analyses the quality of the signal input, improving your viewing experience and delivering superior picture quality.
  • Joiiii design
  • Wide color enhancer
    Using an advanced picture quality improvement algorithm, Samsung's Wide Color Enhancer drastically improves the quality of any image, uncovering hidden details and allowing you to see colors as they were meant to be seen.
  • Create your own entertainment space
    Samsung TVs support HDMI inputs, which lets you create a multimedia entertainment center in your own living room. Connect HDMI straight into your TV to view various contents from multiple devices.
Samsung UE32K4100AK 4 Series - 32" LED-backlit LCD TV - HD
LED-backlit LCD TV
Diagonal Class
32"
Indigo black
Resolution
1366 x 768
Display Format
720p
Frame Rate & Enhancement Technology
100 Picture Quality Index, 50 Motion Rate
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
Wi-Fi (optional)
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
Digital TV Tuner
DVB-C, DVB-T2
Multi-channel Preview
Picture-in-picture (PIP)
Speaker System
2 speakers
USB
Samsung TM1240A remote control, batteries
Voltage
AC 230V (50/60 Hz)
Energy Class
Class A
48 Watt
Power Consumption (On mode)
34 W
Power Consumption Stand by
0.3 Watt
Energy Consumption per Year
50 kWh
72.87 cm x 7.8 cm x 46.88 cm
4.7 kg
LED-backlit LCD TV
Energy Class
Class A
48 Watt
34 W
50 kWh
Diagonal Class
32"
Series
4 Series
TV Tuner Presence
Sensors
Eco Sensor
Video Interface
HDMI Ports Qty
2 ports
Modes
Game mode, Film Mode
Design
Normal Narrow Bezel Design (NNB), Slim Edge Mold Design
Dimensions
Without stand
72.87 cm
7.8 cm
46.88 cm
4.7 kg
Enclosure Colour
Indigo black
Display
Resolution
1366 x 768
Display Format
720p
Image Aspect Ratio
16:9
LED backlight
HyperReal Engine, Wide Color Enhancer Plus, USB Cloning, Digital Clean View, E-Manual, Mega Dynamic Contrast Ratio, Embeded POP
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
DVB-C, DVB-T2
MPEG Profiles and Levels
MHEG5
Video Features
Electronic Programme Guide
Digital EPG
Media Player
USB Port
USB Ports Qty
1
Remote Control
Remote control
Remote Control Model
Samsung TM1240A
Audio System
Digital Audio Format
DTS digital output, Dolby Digital Plus output
Speaker System
2 speakers
Output Power / Total
20 Watt
Wallmount Sound Mode
Speakers
2 x main channel speaker - 10 Watt
Driver Details
Main channel speaker: 2 x full-range driver
Network & Internet Multimedia
Wi-Fi (optional)
Connect & Share
ConnectShare
Connector Type
2 x HDMI , USB 2.0 , Digital audio output (optical) , Composite video / component video input , Audio line-in
Batteries
Power supply
Input Voltage
AC 230V (50/60 Hz)
0.3 Watt
Auto On/Off
Dimensions & Weight Details
Panel without stand - 72.87 cm x 7.8 cm x 46.88 cm x 4.7 kg , Panel with stand - 72.87 cm x 18.53 cm x 52.17 cm x 4.8 kg
Width (Shipping)
79.1 cm
Depth (Shipping)
13.2 cm
Height (Shipping)
52.5 cm
Weight (Shipping)
6.5 kg
C1XD C2G 5m USB 2.0 A/B Cable - Black In Stock £5.09
