Samsung 32" G55A QHD Curved Odyssey Gaming Monitor
Quicklinx: GQW2WS00 Mfr#: LS32AG550EUXXU
165 Hz refresh rate 1 ms response time makes it perfect for crisp and smooth gameplay
Curved Quad HD display offers a lot of detail and fills your field of view much better than a flat display would, making for immersive gaming and viewing
AMD Freesync Premium technology takes care of screen tearing, blurring and other artefacts for smooth action in games, even if your framerate dips lower now and then
VA screen with HDR10 support boasts sharp contrast, deep blacks and wide viewing angles, so it even looks great from the side
  • 165 Hz refresh rate
    The ultrafast 165 Hz refresh rate handles even the most exhilarating scenes and super-quick visuals, meaning it's ready to conquer enemies with no lag and blur.
  • 1 ms response time
    Make every move count with a 1 ms response time. Jump on enemies as soon as you see them and stay ahead with precise mouse movements. Your on-screen performance is as swift as your own reflexes.
  • AMD FreeSync Premium
    Effortlessly smooth gameplay. AMD FreeSync Premium features adaptive sync technology which reduces screen tearing, stutter, and input latency. Low framerate compensation ensures every scene flows seamlessly.
  • Truly realistic HDR
    Inspiring graphics with HDR10. A kaleidoscope of shades brings game scenes to life more vibrantly than ever before. Uncover the secrets hiding in the shadows with deep dark blacks, luminous whites, and outstandingly detailed resolution.
Samsung Odyssey G5 S32AG550EU - LED monitor - curved - 32" - HDR
LED-backlit LCD monitor - 32"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/799107
Energy Class
Class G
Energy Consumption per Year
57 kWh
Curved Screen
Adaptive-Sync Technology
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
WQHD 2560 x 1440 at 165 Hz
Brightness
300 cd/m²
Contrast Ratio
2500:1
HDR Capable
HDR10
Response Time
1 ms (MPRT)
Gaming
Colour Support
16.7 million colours
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Tilt
Voltage
AC 100-240 V (50/60 Hz)
71.01 cm x 27.26 cm x 53.36 cm
5.7 kg
Display Type
Energy Class
Class G
Energy Class (HDR)
Class G
57 kWh
Diagonal Size
32"
Curved Screen
Yes (1000R)
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
2500:1
HDR Format
HDR10
Colour Support
Response Time
1 ms (MPRT)
Gaming
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Cinema Mode, Black eQualizer, CustomColor Mode, FPS Mode, Mega Infinity Dynamic Contrast Ratio, Flicker Free technology, RTS Mode, Eye Saver Mode, Off Timer Plus, Low Input Lag, Super Arena Gaming UX, borderless, Screen Size Optimizer, Refresh Rate Optimizer, RPG Mode, AOS Mode, Dynamic Contrast Mode, Auto Source Switch
71.01 cm x 27.26 cm x 53.36 cm - with stand
5.7 kg
DisplayPort 1.4 , HDMI , Headphones
Mechanical
Tilt
Tilt Angle
-2/+18
VESA Mounting Interface
75 x 75 mm
1 x DisplayPort cable
Security Slot Type
Kensington security slot
Input Voltage
39 kWh/1000h
Power Consumption HDR (On mode)
66 kWh/1000h
Power Consumption (Typical)
39 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 71.01 cm - depth: 27.26 cm - height: 53.36 cm - weight: 5.7 kg , Without stand - width: 71.01 cm - depth: 13.59 cm - height: 43.94 cm - weight: 5.3 kg
Shipping Width
79.4 cm
Shipping Depth
20 cm
Shipping Height
49.4 cm
Shipping Weight
8 kg
10 °C
10 - 80% (non-condensing)
