Samsung 2TB T9 Portable SSD
Quicklinx: HGF4WS00 Mfr#: MU-PG2T0B/EU
Form Factor: [N/A]
Capacity: 2TB, 2TB
Interface: USB 3.2 Gen 2x2
Type: External hard drive
Hurry, only 1 left in stock!
£164.09 ex VAT
£196.90 inc VAT
  • Robust protection
    Equipped with up to 3 m to concrete drop protection and a durable design, this portable external hard drive is designed to withstand the rigors of daily use, ensuring your data is always safe.
  • High-speed transfers
    With an interface speed of 20 Gbps (USB 3.2 Gen 2x2) and a max data transfer rate of 2000 MB/s, transferring large files is swift and efficient, reducing wait times and enhancing productivity.
  • Secure data encryption
    The Samsung T9 features 256-bit AES hardware encryption, providing an extra layer of security for your sensitive information and peace of mind knowing your data is protected.
Samsung T9 MU-PG2T0B - SSD - 2 TB - USB 3.2 Gen 2x2
Solid state drive - external (portable)
2 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
USB 3.2 Gen 2x2 - USB-C
Data Transfer Rate
Password authentication, up to 3m to concrete drop protection
Power Source
USB bus
Enclosure Colour
60 mm x 88 mm x 14 mm
122 g
Europe
5-year warranty
2 TB
Hardware Encryption
256-bit AES
USB 3.2 Gen 2x2
60 mm
88 mm
14 mm
122 g
Performance
Interface Transfer Rate
Max Data Transfer Rate
2000 MB/s
Internal Data Rate
2000 MBps (read) / 1950 MBps (write)
Expansion & Connectivity
1 x USB 3.2 Gen 2x2 - 24 pin USB-C
Power Source
USB bus
Apple MacOS, Android, Windows
USB-C cable , USB-C to USB-A cable
UL, TUV, VCCI, BSMI, CB, IC, FCC, KC, RoHS2, EAC, RCM, BIS, UKCA
Enclosure Colour
Europe
Limited warranty - 5 years
60 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
Form Factor: [N/A]
Capacity: 2TB
Capacity: 2TB
Brand: Samsung
