Samsung 2TB T7 Shield USB 3.2 External SSD - Blue
Quicklinx: GYBHWS00 Mfr#: MU-PE2T0R/EU
Capacity: 2TB, 2TB
Interface: USB 3.2 Gen 2
Type: External hard drive
Hurry, only 2 left in stock!
£390.84 ex VAT
£469.00 inc VAT
Marketing description is not available.
  • Robust design
    The Samsung T7 Shield is built to withstand the challenges of daily use with its shock-resistant feature, ensuring your data stays safe even when life gets bumpy.
  • High-speed transfers
    Experience fast data transfer speeds up to 1050 MB/s, thanks to the USB 3.2 Gen 2 interface. Moving large files or backing up your data takes a fraction of the time.
  • Secure encryption
    With 256-bit AES hardware encryption, the Samsung T7 Shield offers high-level security for your data, giving you peace of mind that your files are protected against unauthorized access.
Samsung T7 Shield MU-PE2T0R - SSD - 2 TB - USB 3.2 Gen 2
Solid state drive - external (portable)
2 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
USB 3.2 Gen 2 - USB-C
Data Transfer Rate
10.0 Gbps (USB 3.2 Gen2)
Shock resistant
Power Source
USB bus
Enclosure Colour
Blue
88.15 mm x 13 mm x 59 mm
98.5 g
3-year warranty
2 TB
Hardware Encryption
256-bit AES
USB 3.2 Gen 2
Shock resistant
88.15 mm
13 mm
59 mm
98.5 g
Performance
Interface Transfer Rate
Max Data Transfer Rate
1050 MB/s
Expansion & Connectivity
1 x USB 3.2 Gen 2 - 24 pin USB-C
Power Source
USB bus
Microsoft Windows 7 or later, Android 5.0 or later, Apple MacOS X 10.10 or later
UL, TUV, VCCI, C-Tick, BSMI, CB, IC, FCC, IP65, KC, RoHS2
Enclosure Colour
Blue
Limited warranty - 3 years
Capacity: 2TB
Capacity: 2TB
Brand: Samsung
