Samsung 2TB T7 Shield USB 3.2 External SSD - Black
Quicklinx: GYB9WS00 Mfr#: MU-PE2T0S/EU
Capacity: 2TB, 2TB
Interface: USB 3.2 Gen 2
Type: External hard drive
£401.92 ex VAT
£482.30 inc VAT
  • Rugged durability
    Tough, fast, and compact. The rugged PSSD T7 Shield is built to endure with the space to create thanks to an IP65 rating for Dust and Water resistance.
  • Keep cool at high speed
    Transfer massive files in seconds. USB 3.2 Gen 2 and PCIe NVMe achieve soaring sequential read/write speeds of up to 1,050/1,000 MB/s, allowing you to edit directly from the drive. The high-tech rubber exterior with Dynamic Thermal Guard controls heat to maintain steady performance for even giant projects.
  • Mighty tough
    Ready for the rough and tumble. Shoot on location and wander the wild while feeling confident your data is securely resistant against water and dust with an IP65 rating. The rugged design and advanced outer elastomer add extra durability to even endure a 9.8-foot drop.
  • Compatible with your devices
    The T7 Shield is compatible with PC, Mac, Android devices, gaming consoles, and more. Included in the box are USB Type C-to-C and Type C-to-A cables for added convenience.
  • Durable yet stylish
    Take your pick, it gives you colossal space. The stylish rubberized grip prevents slips so it stays in your hands. Bring everything with you, and look great doing it.
Samsung T7 Shield MU-PE2T0S - SSD - 2 TB - USB 3.2 Gen 2
Solid state drive - external (portable)
2 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
USB 3.2 Gen 2 - USB-C
Data Transfer Rate
10.0 Gbps (USB 3.2 Gen2)
Shock resistant
Power Source
USB bus
Enclosure Colour
88.15 mm x 13 mm x 59 mm
98.5 g
3-year warranty
2 TB
Hardware Encryption
256-bit AES
USB 3.2 Gen 2
Shock resistant
88.15 mm
13 mm
59 mm
98.5 g
Performance
Interface Transfer Rate
Max Data Transfer Rate
1050 MB/s
Expansion & Connectivity
1 x USB 3.2 Gen 2 - 24 pin USB-C
Power Source
USB bus
Microsoft Windows 7 or later, Android 5.0 or later, Apple MacOS X 10.10 or later
UL, TUV, VCCI, C-Tick, BSMI, CB, IC, FCC, IP65, KC, RoHS2
Enclosure Colour
Limited warranty - 3 years
Capacity: 2TB
Capacity: 2TB
Brand: Samsung
