Samsung 2TB Story Station 3.5" USB 2.0 Desktop Hard Drive
Quicklinx: 6L8PWS00 Mfr#: HX-DU020EB/F62
Samsung has developed solid, reliable data storage to store your precious memories up to 2TB. The Story Station safely downloads and protects your lifetime memories - video clips, photos, music files, and important data - that are so valuable and not easily replaced. Samsung Story Station is the best storage solution to capture and preserve your life story.
  • Sleek design
    Minimalism is the design concept of Story Station. Every element - the finely brushed metal finish, simple jog dial, and red-belted cable outlets - underscores the sleek and refined style. The sharp contrast of gray and red is eye-catching and the solid, simple cover creates timeless beauty. A simple but classical jog dial functions as a power switch and reflecting LED light, hidden on the bottom, softly displays power on/off status.
  • Enhanced data protection
    The Story Station is built to store your valuable data safely and keep it backed up using the Samsung Auto Backup and Safety Key features. Moreover, you can protect private and confidential files and folders in the virtual drive, SecretZone, with complete confidence.
  • Green operation
    Samsung's environment-friendly product supports "Power Saving Mode," which saves power by automatically going into standby mode after 5 minutes of inactivity. The Story Station's heat dissipating design - the ventilation and the aluminum cover - prevents heat buildup and keeps the drive inside cool.
  • Easy to set up, easy to use
    Simply plug it in and go. No CD is needed for installation. You can see at a glance how much space is available, used, or designated as backup storage.
3.5"
2TB
