The latest model of the world's best-selling SSD series has finally arrived. The 870 EVO inherits the legacy of Samsung's pioneering SSD technology, boasting upgraded performance, reliability and compatibility to suit the needs of anyone from content creators and IT professionals to everyday users.
                Excellence in performanceThe 870 EVO achieves the maximum SATA interface limit of 560/530 MB/s sequential speeds. Everyday users can now enjoy professional-level SSD performance. Intelligent TurboWrite accelerates write speeds and maintains long-term high performance with a larger variable buffer.
                Industry-defining reliabilityProviding up to 2,400 TBW the 870 EVO meets the industry's leading standards of reliability. It withstands tasks from everyday computing to 8K video processing and comes equipped with the latest 6th Gen. VNAND and MKX controller that ensure a stable host experience.
                More compatible than everThe 870 EVO passed compatibility tests with major host systems and applications, including chipsets, motherboards, NAS and video recording devices. As the latest entry in the globally best-selling EVO series, the 870 EVO's proven versatility is compatible with any user's systems and tasks.
                Upgrade with easeUpgrading to the 870 EVO is made easy for anyone with a desktop PC or laptop that supports a standard 2.5-inch SATA form factor. Enjoying this masterpiece SSD is as convenient as plugging in the 870 EVO into a SATA slot and letting the renewed migration software take care of the rest.
                Samsung Magician softwareMake your drive work like magic. The new and improved Samsung Magician 6 software will keep your SSD in check. You can easily manage your drive with a wide range of useful tools to keep up with the latest updates, monitor the drive's health and status, or even enhance its performance.
- Samsung 870 EVO MZ-77E2T0B - SSD - 2 TB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 2 TB
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES
- NAND Flash Memory Type
- 3D multi-level cell (MLC)
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 2 GB
- TRIM support, sleep mode, Auto Garbage Collection Algorithm, Worldwide Name (WWN), TurboWrite Technology, 3-bit 3D V-NAND Technology, Low Power DDR4 SDRAM Cache, Samsung MKX Controller, S.M.A.R.T., 256-bit AES, IEEE 1667
- 69.85 mm x 100 mm x 6.8 mm
- 45 g
- 5-year warranty
- Capacity
- 2 TB
- 256-bit AES
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 2 GB
- 69.85 mm
- 100 mm
- 6.8 mm
- 45 g
Performance
- SSD Endurance
- 1200 TB
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 560 MBps (read) / 530 MBps (write)
- 4KB Random Read
- 13000 IOPS
- 4KB Random Write
- 36000 IOPS
- Maximum 4KB Random Write
- 88000 IOPS
- Maximum 4KB Random Read
- 98000 IOPS
Reliability
- MTBF
- 1,500,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 2.5"
- Power Consumption
- 5 Watt (average) , 4.5 Watt (maximum)
- Software Included
- Samsung Magician Software
- WWN, IEEE 1667
- Limited warranty - 5 years / 1200 TBW
- 0 °C
- 70 °C
- Shock Tolerance (operating)
- 1500 g @ 0.5 ms half-sine
