The Samsung S27C310EAU LED-backlit LCD monitor is designed to deliver a high-quality viewing experience with its 27-inch Full HD display, offering vibrant colors and sharp details. With AMD FreeSync technology, gamers can enjoy smooth gameplay without tearing and stuttering, while the wide 178-degree viewing angles make this monitor ideal for watching movies or working with multiple windows. The monitor also prioritizes your comfort with features like Flicker-Free technology and Eye Saver Mode, reducing eye strain during long sessions. Additionally, its energy-efficient design, including Eco Saving Plus, ensures that you're not only saving on costs but also contributing to a greener planet. Whether for work, play, or anything in between, the Samsung S27C310EAU is a versatile choice that combines performance with sustainability.
Clear and clutter-free view
See what's on screen without distraction. The 3-sided borderless display brings a clean and modern aesthetic to any home office or working space. In a multi-monitor setup, the displays line up for a virtually gapless view for uninterrupted viewing. -
See from all angles with enhanced accuracy
You can focus on your screen comfortably, no matter where you are. The IPS panel preserves color vividness and clarity across the screen, while presenting tones and shades with reduced color washing to bring important details to life. -
Seamless gaming experience
Low latency gameplay experience. AMD Radeon FreeSync keeps your monitor and graphics card refresh rate in sync to reduce image tearing. Stay entertained without any interruptions. Even fast scenes look seamless and smooth. -
Synchronized gameplay
Fluid visuals for viewing that flows. The 75 Hz refresh rate delivers smoother scenes. When playing a game, watching a YouTube video or catching up on other content, your entertainment has reduced lag and ghosting effect. -
More gaming power
Gain the edge with optimizable game settings. Color and image contrast can be instantly adjusted to see scenes more vividly and spot enemies hiding in the dark, while Game mode adjusts any game to fill your screen with every detail in view. -
Comfortable eye care
Protect your eyes and do more. Advanced TUV certified eye comfort technology reduces eye strain, minimizing blue light while removing irritating screen flicker. -
Energy-saving auto brightness setting
Globally certified for energy efficiency, Samsung monitor features Eco saving plus mode that preserves up to 10% more energy. -
Enhanced versatility
Connect to more. Plug devices straight into your monitor for increased flexibility, making your computing environment even more convenient.
 - Samsung S27C310EAU - LED monitor - Full HD (1080p) - 27"
 - LED-backlit LCD monitor - 27"
- Aspect Ratio
 - 16:9
- Native Resolution
 - Full HD (1080p) 1920 x 1080
 - Tilt
- Display Type
- Diagonal Size
 - 27"
- Aspect Ratio
 - 16:9
- Native Resolution
- Horizontal Viewing Angle
 - 178
- Vertical Viewing Angle
 - 178
- Backlight Technology
 - LED backlight
Mechanical
 - Tilt
