Samsung 28" G70B Ultra HD 144Hz Smart Odyssey Gaming Monitor
Quicklinx: H65DWS00 Mfr#: LS28BG700EPXXU
Diagonal Size: 28in
Max Resolution: 3840 x 2160
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: HDMI, DisplayPort
£482.50 ex VAT
£579.00 inc VAT
  • Hyper-realistic worlds on your screen
    Uncover every detail with maximum clarity. Packing in 4 times the pixel density of Full HD, see games like never before. IPS panel delivers clear colors and a wide 178° viewing angle for clarity from any viewpoint. With more pixels and greater depth, games are closer to reality than you could've imagined.
  • DisplayHDR 400
    Reveal the whole picture. DisplayHDR 400 delivers more contrast, with deeper blacks and brighter whites to help you uncover enemies or secrets lurking in the shadows. Even in dark scenes, every detail shines with clarity.
  • G-Sync and FreeSync Premium Pro
    Hyper action made seamless. G-Sync compatibility keeps the GPU and panel synced up to eliminate choppiness, screen-lag, and image tears. Fast-action and complex game scenes are stable and stutter-free with AMD FreeSync Premium Pro for a competitive edge.
  • Incredible 4K gaming refresh rates
    Conquer every enemy, even at extreme speeds. The 144Hz refresh rate eliminates lag for exhilarating gameplay with ultra-smooth action. Identify enemies with elite precision thanks to a 1ms response time, precise mouse movements, and blur-free frames with minimized ghosting.
  • Samsung Gaming Hub
    The best of gaming all in one place. Samsung Gaming Hub allows instant access to top cloud gaming services, as well as your favorite console games. Smooth visuals and responsive gameplay are powered by advanced game streaming technology without downloads or storage limits - just turn on and play.
  • Quick, simple setup to seize the win
    Check and control game settings in an instant. You can easily view the status of the most important settings such as FPS or HDR. Modify response time or screen ratio, as well as the game picture mode without having to leave your game screen to stay focused on your goals.
  • Your games tailored to you
    Reach the height of success. Swivel, tilt, and adjust your monitor until all enemies are in perfect view. Your display can be moved freely so you can find total gaming comfort.
  • Your favorite shows in one space
    Take a break from marathon gaming sessions and catch up on must-see streaming content in 4K HDR, with only a Wi-Fi connection. Samsung TV Plus offers free live content with no downloads or sign-ups, as well as personalized content recommendations from Universal Guide.
  • Ultrawide Game View
    Find more with an extended view. Discover hidden gems or flank enemies in full stealth with the ultra-wide 21:9 aspect ratio. Extra context in every match brings you closer to the top of the leaderboard.
  • Designed to light up your world
    With core lighting, add personality to your setup with multiple color modes that leap off the screen and into your reality. Gaming escapes beyond the screen with ambient CoreSync technology that matches your game's on-screen colors for world-blending immersion.
  • Instant auto connect
    Power on for instant action. With Auto Source Switch+, your monitor detects when connected devices are turned on and instantly switches to the new source signal. This helps you get to your game play faster without flipping through multiple input sources.
Samsung Odyssey G7 S28BG700EP - G70B Series - LED monitor - 4K - 28" - HDR
LED-backlit LCD monitor - 28" - Smart monitor
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/1420497
Energy Class
Class F
Energy Consumption per Year
40 kWh
Adaptive-Sync Technology
AMD FreeSync Premium Pro, NVIDIA G-SYNC Compatible
Wi-Fi, USB 3.0 hub, Gigabit Ethernet network adapter, Bluetooth 5.2 adapter
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 144 Hz
Brightness
300 cd/m²
Contrast Ratio
1000:1
HDR Capable
HDR10+ / DisplayHDR 400
Response Time
1 ms (grey-to-grey)
Gaming
Colour Support
1 billion colours
Colour Gamut
90% DCI
Input Connectors
2xHDMI, DisplayPort
Built-in Ethernet
Display Position Adjustments
Voltage
AC 100-240 V
63.79 cm x 24.48 cm x 57.7 cm
7 kg
CEC
Display Type
LED-backlit LCD monitor / TFT active matrix - Smart monitor
Energy Class
Class F
Energy Class (HDR)
Class G
40 kWh
Diagonal Size
28"
Operating System
Tizen
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
1000:1
HDR Format
HDR10+
HDR Certification
DisplayHDR 400
Colour Support
1 billion colours
Colour Gamut
90% DCI
Response Time
1 ms (grey-to-grey)
Gaming
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Game mode, ConnectShare, Eco Light Sensor, Flicker Free technology, Image Size, Eye Saver Mode, Factory Tunning, Factory Calibration Report, Movie Mode, DLNA, Graphics Mode, Dynamic Contrast Mode, Auto Source Switch+, Adaptive Picture, Ultrawide Game View, Tap View, Sound Mirroring, SmartThings App Support, CoreSync lighting design, Adaptive Sound, Game Bar 2.0, far-field voice interaction, Virtual AIM Point, Bixby Voice Assistant, Mobile to Screen Mirroring, Gaming Hub, SmartThings, Workspace, Samsung TV Plus, Entertain Mode
63.79 cm x 24.48 cm x 57.7 cm - with stand
7 kg
Audio
Speakers
2 x HDMI , DisplayPort 1.4 , Headphone jack (mini-jack) , 2 x USB 3.0 , LAN (RJ-45)
Mechanical
Tilt Angle
-9/+13
Swivel Angle
30
Rotation Angle
-92/+92
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm
Remote control
1 x DisplayPort cable
CEC
Security Slot Type
Kensington security slot
Input Voltage
AC 100-240 V
27 kWh/1000h
Power Consumption HDR (On mode)
55 kWh/1000h
Power Consumption (Typical)
27.2 Watt
Power Consumption (Max)
80 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Intel Wireless Display, Microsoft 365, SmartThings, Samsung TV Plus, Google Duo, Bixby Voice Assistant
Dimensions & Weight Details
With stand - width: 63.79 cm - depth: 24.48 cm - height: 57.7 cm - weight: 7 kg , Without stand - width: 63.79 cm - depth: 10.86 cm - height: 38.05 cm - weight: 5.1 kg
Shipping Width
71.6 cm
Shipping Depth
16.9 cm
Shipping Height
48.9 cm
Shipping Weight
9.6 kg
10 °C
10 - 80% (non-condensing)
Diagonal Size: 28in
Response Time: 1ms
Interfaces: HDMI
Interfaces: DisplayPort
Brand: Samsung
