Super-fast performance
Gain the edge over your opponents with the Samsung Odyssey G7 LS28AG700NUXXU 4K Ultra HD 28" LED Gaming Monitor.
Its 1 ms response time lets you make fast and precise mouse movements, often the crucial factor in a big multiplayer. And the 144 Hz refresh rate means you won't miss a frame, even in fast-paced FPS games.
Ultra-smooth visuals
4K Ultra HD resolution with HDR400 means you get all the detail with rich colours. White shades shine brightly, while blacks are truly black. So you'll be able to see more in the shadows, and spot your enemies sooner.
The Odyssey G7 also features AMD FreeSync Premium Pro and NVIDIA G-Sync compatibility, syncing the refresh rate to your graphics card for tear-free smoothness.
- Samsung Odyssey G7 S28AG700NU - LED monitor - 4K - 28" - HDR
- LED-backlit LCD monitor - 28"
- Energy Class
- Class G
- Energy Consumption per Year
- 48 kWh
- Adaptive-Sync Technology
- AMD FreeSync Premium Pro, NVIDIA G-SYNC Compatible
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160 at 144 Hz
- Pixel Pitch
- 0.16 mm
- Brightness
- 400 cd/m²
- Contrast Ratio
- 1000:1
- HDR Capable
- DisplayHDR 400
- Response Time
- 1 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 90% DCI
- Input Connectors
- 2xHDMI, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 100-240 V
- Black
- 63.69 cm x 24.7 cm x 57.41 cm
- 7.9 kg
- 2-year warranty
- Display Type
- Energy Class
- Class G
- Energy Class (HDR)
- Class G
- 48 kWh
- Diagonal Size
- 28"
- Viewable Size
- 27.9"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.16 mm
- Brightness
- 400 cd/m²
- Contrast Ratio
- 1000:1
- HDR Certification
- DisplayHDR 400
- Colour Support
- Colour Gamut
- 90% DCI
- Response Time
- Vertical Refresh Rate
- 48 - 144 Hz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Cinema Mode, Black eQualizer, CustomColor Mode, FPS Mode, Mega Infinity Dynamic Contrast Ratio, Flicker Free technology, RTS Mode, Eco Saving Plus, Eye Saver Mode, Factory Tunning, Factory Calibration Report, Off Timer Plus, Low Input Lag, Super Arena Gaming UX, Screen Size Optimizer, Refresh Rate Optimizer, Custom Key, RPG Mode, AOS Mode, sRGB Mode, Picture-in-Picture, Dynamic Contrast Mode, Auto Source Switch+, Ultrawide Game View, High Bright mode, CoreSync lighting design
- Black
- 63.69 cm x 24.7 cm x 57.41 cm - with stand
- 7.9 kg
- 2 x HDMI , DisplayPort , Headphones , USB 3.0
Mechanical
- Tilt Angle
- -9/+13
- Swivel Angle
- 30
- Rotation Angle
- -2/+92
- Height Adjustment
- 120 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x DisplayPort cable , 1 x SuperSpeed USB cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- AC 100-240 V
- Power Consumption SDR (On mode)
- 33 kWh/1000h
- Power Consumption HDR (On mode)
- 50 kWh/1000h
- Power Consumption (Typical)
- 33 Watt
- Power Consumption (Max)
- 78 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 63.69 cm - depth: 24.7 cm - height: 57.41 cm - weight: 7.9 kg , Without stand - width: 63.69 cm - depth: 12.21 cm - height: 37.99 cm - weight: 6.2 kg
- Shipping Width
- 71.1 cm
- Shipping Depth
- 47.5 cm
- Shipping Height
- 19.1 cm
- Shipping Weight
- 10.5 kg
- Limited warranty - 2 years
- 10 °C
- 40 °C
- 10 - 80% (non-condensing)
