Samsung 27" M50D FHD Monitor with Speakers & Remote
Quicklinx: HTTKWS00 Mfr#: LS32DM500EUXXU
Diagonal Size: 32in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: HDMI
14 In Stock
£207.03 ex VAT
£248.43 inc VAT
Watch, Play, Work in Style
A Monitor & Streaming TV All in One
Smart TV Apps
Have to make the most out of a small space, or simply want a second TV? The Smart Monitor is the best choice. Stream OTT content directly from the monitor, or tune into Samsung TV Plus to get live TV channels and on-demand content at zero cost.
Multiple Ports Connect easily and create your customized set up using HDMI and USB-A ports without any adapters. Plug in to create your ideal multi-screen station.
Gaming Hub
Samsung Gaming Hub is the ultimate home for gaming. Instantly play the biggest games from top streaming partners, with no PC or console needed. Discover new games or replay old favorites all in one place.
SmartThings
See all your smart home devices in a new 3D Map View, for an easier way to manage devices in different rooms. See energy usage and costs by device, and save money by turning on energy saving modes. Use your mobile phone to tap into the all-in-one IoT hub - all without pausing shows.
Workout Tracker
Forget about boring workouts. Stream workout content, or run your own workout while watching contents on the Smart Monitor. Pair your Galaxy Watch to track real-time health data on the screen, while keeping streaming content on at the same time.
Workspace
Access and control your PC remotely, or work directly on the monitor. Embedded productivity apps like Microsoft 365 let you bypass the PC for a simpler, streamlined working environment.
Multi Control
Maximize your multitasking capabilities by effortlessly controlling multiple devices with a single mouse and keyboard. Experience greater efficiency with a single control station for your Smart Monitor, Galaxy Tab and Galaxy mobile device.
  • High-quality display
    The monitor features a native resolution of 1920 x 1080 with an image brightness of 250 cd/m² and a contrast ratio of 3000:1, ensuring vivid and sharp images.
  • Versatile connectivity
    With built-in Wi-Fi, Bluetooth 5.2, and a USB hub, the monitor offers various connectivity options, allowing users to link multiple devices effortlessly.
  • Gaming enhancements
    Equipped with features like Game Bar 2.0 and Virtual AIM Point, the monitor caters to gamers, enhancing the interactive experience.
  • Comfortable viewing experience
    Flicker-Free technology and Eye Saver Mode work together to reduce eye fatigue, making it suitable for extended use.
  • Smart functionalities
    The monitor supports Tizen OS, allowing access to smart apps, remote access features, and mobile screen mirroring for a versatile user experience.
Samsung S32DM500EU - M50D Series - LED monitor - Full HD (1080p) - 32" - HDR
LED-backlit LCD monitor - 32" - Smart monitor
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/1926753
Energy Class
Class E
Energy Consumption per Year
38 kWh
Remote control, USB Hub, Wi-Fi, Bluetooth 5.2 adapter
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.369 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1
HDR Capable
HDR10
Response Time
4 ms (grey-to-grey)
Colour Support
1 billion colours
Colour Gamut
72% (NTSC 1976)
Input Connectors
2xHDMI
Display Position Adjustments
Tilt
Voltage
AC 100-240 V
71.61 cm x 19.35 cm x 51.7 cm
6.2 kg
CEC, HDCP 2.2
Display Type
LED-backlit LCD monitor / TFT active matrix - Smart monitor
Energy Class
Class E
Energy Class (HDR)
Class G
38 kWh
Diagonal Size
32"
Operating System
Tizen
Built-in Devices
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.369 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1
HDR Format
HDR10
Colour Support
1 billion colours
Colour Gamut
72% (NTSC 1976)
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
MultiView, Flicker Free technology, Image Size, Eye Saver Mode, Auto Source Switch+, Adaptive Picture, Ultrawide Game View, Tap View, Remote Access, Sound Mirroring, wireless casting, Game Bar 2.0, Virtual AIM Point, Mobile to Screen Mirroring, Gaming Hub, SmartThings, Samsung TV Plus, Nifty Gateway, My Contents
71.61 cm x 19.35 cm x 51.7 cm - with stand
6.2 kg
Audio
Speakers - stereo
Output Power / Channel
5 Watt
Input
Remote control
2 x HDMI (HDCP 2.2) , 2 x USB
Mechanical
Tilt
Tilt Angle
-2/+22
VESA Mounting Interface
100 x 100 mm
Remote control
1 x HDMI cable
CEC, HDCP 2.2
Security Slot Type
Kensington security slot
Input Voltage
AC 100-240 V
26 kWh/1000h
Power Consumption HDR (On mode)
38 kWh/1000h
Power Consumption (Typical)
26 Watt
Power Consumption (Max)
60 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Microsoft 365
Dimensions & Weight Details
With stand - width: 71.61 cm - depth: 19.35 cm - height: 51.7 cm - weight: 6.2 kg , Without stand - width: 71.61 cm - depth: 4.18 cm - height: 42.45 cm - weight: 5.1 kg
Shipping Width
84.2 cm
Shipping Depth
48.7 cm
Shipping Height
13.3 cm
Shipping Weight
8.1 kg
10 °C
10 - 80% (non-condensing)
Diagonal Size: 32in
Response Time: 4ms
Interfaces: HDMI
Brand: Samsung
