Samsung 27" G51C QHD 165Hz Odyssey Gaming Monitor
Quicklinx: HTT7WS00 Mfr#: LS27CG510EUXXU
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 1ms
Speakers: None
Interfaces: DisplayPort, HDMI
17 In Stock
£151.84 ex VAT
£182.20 inc VAT
The Samsung Odyssey G5 S27CG510EU is designed to elevate your gaming experience. Featuring a 27-inch QHD display with HDR10, it delivers stunning visuals with deep contrasts and vibrant colors. The monitor's 165 Hz refresh rate and 1 ms response time ensure that every frame is rendered with precision, providing a smooth gaming experience. AMD FreeSync Premium technology eliminates screen tearing, allowing for seamless gameplay even in the most action-packed scenes.
Ergonomically designed, the Odyssey G5 offers extensive adjustability including height, pivot, swivel, and tilt, ensuring you can game in comfort for hours. It also comes equipped with a variety of gaming modes to enhance your play. Connectivity is a breeze with multiple input options, and features like Auto Source Switch and Off Timer Plus add to its convenience. Whether you're a competitive gamer or a casual player, the Samsung Odyssey G5 is built to meet your needs, offering a blend of performance, comfort, and convenience.
  • Boost your reality
    Your gaming world, more lifelike than ever before. QHD resolution boasts incredibly detailed, pin-sharp images. Experience a fuller view with more space to take in all the action.
  • Find hidden details others miss
    Awe-inspiring graphics with HDR10. A kaleidoscope of shades brings game scenes to life with incredible vibrancy. Uncover the secrets hiding in the shadows with deep dark blacks, luminous whites, and outstandingly detailed resolution.
  • React in real time
    Speed through scenes. 165Hz refresh rate eliminates lag for exhilarating gameplay with ultra-smooth action. Jump on enemies right when you see them with a 1ms response time (MPRT) for frames with minimal blur.
  • Uninterrupted game flow
    Effortlessly smooth gameplay. AMD FreeSync Premium features adaptive sync technology which reduces screen tearing, stutter, and input latency. Low frame rate compensation ensures every scene flows seamlessly.
  • Ergonomic design
    Reach the height of winning. Swivel, tilt, and adjust your monitor until all enemies are in perfect view. Your display can be moved freely so you can find total gaming comfort.
Samsung Odyssey G5 S27CG510EU - G51C Series - LED monitor - QHD - 27" - HDR
LED-backlit LCD monitor - 27"
Energy Class
Class F
Energy Consumption per Year
37 kWh
Adaptive-Sync Technology
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 165 Hz
Pixel Pitch
0.2335 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1
HDR Capable
HDR10
Response Time
1 ms (MPRT)
Gaming
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Voltage
AC 100-240 V
61.82 cm x 23.42 cm x 52.06 cm
4.8 kg
HDCP 1.4
Display Type
Energy Class
Class F
Energy Class (HDR)
Class G
37 kWh
Diagonal Size
27"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2335 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1
HDR Format
HDR10
Colour Support
Colour Gamut
72% NTSC
Response Time
1 ms (MPRT)
Gaming
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Game mode, Cinema Mode, Mega Dynamic Contrast Ratio, Black eQualizer, FPS Mode, Flicker Free technology, RTS Mode, Eye Saver Mode, Off Timer Plus, Super Arena Gaming UX, Refresh Rate Optimizer, RPG Mode, AOS Mode, sRGB Mode, 3-sided bezeless, Dynamic Contrast Mode, Auto Source Switch, Virtual AIM Point
61.82 cm x 23.42 cm x 52.06 cm - with stand
4.8 kg
DisplayPort 1.4 , 2 x HDMI (HDCP 1.4) , Headphones (mini-jack)
Mechanical
Tilt Angle
-5/+20
Swivel Angle
30
Rotation Angle
-2/+92
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm
1 x DisplayPort cable
HDCP 1.4
Security Slot Type
Kensington security slot
Input Voltage
AC 100-240 V
25 kWh/1000h
Power Consumption HDR (On mode)
38 kWh/1000h
Power Consumption (Typical)
25.2 Watt
Power Consumption (Max)
48 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 61.82 cm - depth: 23.42 cm - height: 52.06 cm - weight: 4.8 kg , Without stand - width: 61.82 cm - depth: 9.24 cm - height: 37.69 cm - weight: 3.3 kg
Shipping Width
70.2 cm
Shipping Depth
19.2 cm
Shipping Height
46.5 cm
Shipping Weight
7 kg
10 °C
10 - 80% (non-condensing)
Diagonal Size: 27in
Response Time: 1ms
Speakers: None
Interfaces: HDMI
Brand: Samsung
