Escape into reality-defying realism. You can see games like never before. IPS panel delivers clear colors and a wide 178º viewing angle for clarity from any viewpoint. With more pixels and greater depth, games are closer to reality than ever before.
Speed through scenes. 240 Hz refresh rate eliminates lag for exhilarating gameplay with ultra-smooth action. Jump on enemies right when you see them with a 1 ms response time and blur-free frames.
Boost your reality
Escape into reality-defying realism. You can see games like never before. IPS panel delivers clear colors and a wide 178º viewing angle for clarity from any viewpoint. With more pixels and greater depth, games are closer to reality than ever before. -
React in real time
Speed through scenes. 240 Hz refresh rate eliminates lag for exhilarating gameplay with ultra-smooth action. Jump on enemies right when you see them with a 1 ms response time and blur-free frames. -
Focus without ever breaking flow
Effortlessly smooth gameplay. G-Sync compatibility keeps the GPU and panel synced up to eliminate choppiness, screen-lag, and image tears. Fast-action and complex game scenes are stable and stutter-free with AMD FreeSync Premium for your competitive edge. -
Reveal the game's hidden sides
Keep your eye on the win. Adjust your screen to 21:9 to discover hidden areas in game scenes with ultrawide game view. When you play soccer games, see more of the pitch right up to the goalposts. And in driving games, get a natural and encompassing view of the road ahead. -
Connect automatically, in an instant
Power on for instant play. With Auto Source Switch+, your monitor detects when connected devices are turned on and instantly switches to the new source signal. This helps you get to your game action faster without flipping through multiple input sources. -
See your game your way
Reach the height of winning. Swivel, tilt, and adjust your monitor until all enemies are in perfect view. Your display can be moved freely so you can find total gaming comfort.
- Samsung Odyssey G4 S27BG400EU - G40B Series - LED monitor - Full HD (1080p) - 27" - HDR
- LED-backlit LCD monitor - 27"
- Energy Class
- Class E
- Energy Consumption per Year
- 31 kWh
- Adaptive-Sync Technology
- AMD FreeSync Premium, NVIDIA G-SYNC Compatible
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 240 Hz
- Brightness
- 400 cd/m²
- Contrast Ratio
- 1000:1
- HDR Capable
- HDR10
- Response Time
- 1 ms (grey-to-grey)
- Gaming
- Colour Support
- 16.7 million colours
- Colour Gamut
- 99% sRGB
- Input Connectors
- 2xHDMI, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 100-240 V (50/60 Hz)
- Black
- 61.47 cm x 24.48 cm x 57.11 cm
- 5.3 kg
- HDCP 2.2
- Display Type
- Energy Class
- Class E
- Energy Class (HDR)
- Class G
- 31 kWh
- Diagonal Size
- 27"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 400 cd/m²
- Contrast Ratio
- 1000:1
- HDR Format
- HDR10
- Colour Support
- Colour Gamut
- 99% sRGB
- Response Time
- Gaming
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Mega Infinity Dynamic Contrast Ratio, Eco Saving Plus, Eco Light Sensor, Eye Saver Mode, Flicker Free technology, Low Input Lag, Off Timer, Virtual AIM Point, Super Arena Gaming UX, Refresh Rate Optimizer, Auto Source Switch+, Adaptive Picture, FPS Mode, RTS Mode, RPG Mode, Sports Mode, sRGB Mode, Cinema Mode, Dynamic Contrast Mode, ergonomic stand, Ultrawide Game View, CustomColor Mode
- Black
- 61.47 cm x 24.48 cm x 57.11 cm - with stand
- 5.3 kg
- DisplayPort 1.2 , 2 x HDMI , Headphones
Mechanical
- Tilt Angle
- -3/+22
- Swivel Angle
- 30
- Rotation Angle
- -92/+92
- Height Adjustment
- 120 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x HDMI cable
- HDCP 2.2
- Input Voltage
- Power Consumption SDR (On mode)
- 21 kWh/1000h
- Power Consumption HDR (On mode)
- 45 kWh/1000h
- Power Consumption (Typical)
- 21 Watt
- Power Consumption (Max)
- 48 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 61.47 cm - depth: 24.48 cm - height: 57.11 cm - weight: 5.3 kg , Without stand - width: 61.74 cm - depth: 8.54 cm - height: 37.66 cm - weight: 3.6 kg
- Shipping Width
- 68.5 cm
- Shipping Depth
- 46.9 cm
- Shipping Height
- 16.8 cm
- Shipping Weight
- 7 kg
- 10 °C
- 40 °C
- 10 - 80% (non-condensing)
