Samsung 27" G40B Odyssey G4 Gaming Monitor
Quicklinx: H3NMWS00 Mfr#: LS27BG400EUXXU
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: None
Interfaces: HDMI, DisplayPort
£215.84 ex VAT
£259.00 inc VAT
Express delivery Order within the next 22 hours for delivery on Thursday
Escape into reality-defying realism. You can see games like never before. IPS panel delivers clear colors and a wide 178º viewing angle for clarity from any viewpoint. With more pixels and greater depth, games are closer to reality than ever before.
Speed through scenes. 240 Hz refresh rate eliminates lag for exhilarating gameplay with ultra-smooth action. Jump on enemies right when you see them with a 1 ms response time and blur-free frames.
  • Boost your reality
  • React in real time
  • Focus without ever breaking flow
    Effortlessly smooth gameplay. G-Sync compatibility keeps the GPU and panel synced up to eliminate choppiness, screen-lag, and image tears. Fast-action and complex game scenes are stable and stutter-free with AMD FreeSync Premium for your competitive edge.
  • Reveal the game's hidden sides
    Keep your eye on the win. Adjust your screen to 21:9 to discover hidden areas in game scenes with ultrawide game view. When you play soccer games, see more of the pitch right up to the goalposts. And in driving games, get a natural and encompassing view of the road ahead.
  • Connect automatically, in an instant
    Power on for instant play. With Auto Source Switch+, your monitor detects when connected devices are turned on and instantly switches to the new source signal. This helps you get to your game action faster without flipping through multiple input sources.
  • See your game your way
    Reach the height of winning. Swivel, tilt, and adjust your monitor until all enemies are in perfect view. Your display can be moved freely so you can find total gaming comfort.
Samsung Odyssey G4 S27BG400EU - G40B Series - LED monitor - Full HD (1080p) - 27" - HDR
LED-backlit LCD monitor - 27"
Energy Class
Class E
Energy Consumption per Year
31 kWh
Adaptive-Sync Technology
NVIDIA G-SYNC Compatible, AMD FreeSync Premium
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 240 Hz
Brightness
400 cd/m²
Contrast Ratio
1000:1
HDR Capable
HDR10
Response Time
1 ms (grey-to-grey)
Gaming
Colour Support
16.7 million colours
Colour Gamut
99% sRGB
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Voltage
AC 100-240 V (50/60 Hz)
61.47 cm x 24.48 cm x 57.11 cm
5.3 kg
HDCP 2.2
Display Type
Energy Class
Class E
Energy Class (HDR)
Class G
31 kWh
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
400 cd/m²
Contrast Ratio
1000:1
HDR Format
HDR10
Colour Support
Colour Gamut
99% sRGB
Response Time
1 ms (grey-to-grey)
Gaming
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Cinema Mode, Eco Light Sensor, CustomColor Mode, FPS Mode, Mega Infinity Dynamic Contrast Ratio, Flicker Free technology, RTS Mode, Eco Saving Plus, Eye Saver Mode, Sports Mode, Low Input Lag, Super Arena Gaming UX, Refresh Rate Optimizer, RPG Mode, sRGB Mode, Off Timer, Dynamic Contrast Mode, Auto Source Switch+, Adaptive Picture, Ultrawide Game View, ergonomic stand, Virtual AIM Point
61.47 cm x 24.48 cm x 57.11 cm - with stand
5.3 kg
DisplayPort 1.2 , 2 x HDMI , Headphones
Mechanical
Tilt Angle
-3/+22
Swivel Angle
30
Rotation Angle
-92/+92
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable
HDCP 2.2
Input Voltage
21 kWh/1000h
Power Consumption HDR (On mode)
45 kWh/1000h
Power Consumption (Typical)
21 Watt
Power Consumption (Max)
48 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 61.47 cm - depth: 24.48 cm - height: 57.11 cm - weight: 5.3 kg , Without stand - width: 61.74 cm - depth: 8.54 cm - height: 37.66 cm - weight: 3.6 kg
Shipping Width
68.5 cm
Shipping Depth
46.9 cm
Shipping Height
16.8 cm
Shipping Weight
7 kg
10 °C
10 - 80% (non-condensing)
Diagonal Size: 27in
Response Time: 1ms
Speakers: None
Interfaces: HDMI
Interfaces: DisplayPort
Brand: Samsung
Stock Status: While stocks last
Stock Status: Clearance
