The curvature of Samsung CF591 provides a truly immersive viewing experience that lets you enjoy big, bold and stunning panoramic views while you work or play. With its design inspired by the curve of the human eye, the Samsung CF591 monitor delivers a comfortable and enjoyable viewing experience for your home or office use. It boasts sleek curves and a stylish design that will compliment any room. Experience vibrant, stunningly vivid colors with Samsung's Active Crystal Color technology. The excellent 3000:1 contrast ratio delivers deeper blacks and brighter whites so you can clearly see even in an extremely dark or bright scene.
Immersive viewing experience with curved screen
The 1800 R curvature of the screen provides a truly immersive viewing experience that lets you enjoy big, bold and stunning panoramic views while you work or play. With its design inspired by the curve of the human eye, the Samsung CF591 monitor delivers a comfortable and enjoyable viewing experience for your home or office use. -
Sleek, curved design
Featuring a glossy body and metallic finish, the Samsung CF591 monitor boasts sleek curves and a stylish design that will compliment any room. The simple, circular stand will help add an ultimate look to your work space. -
Advanced gaming experience with AMD FreeSync
AMD FreeSync technology allows users to enjoy smooth images, even during the fastest moving scenes. AMD FreeSync dynamically syncs the screen refresh rate with the frame rate of your content to minimize input latency and dramatically reduce image tearing and stutter during gaming. With its 4 ms response time, you'll see the ultra-fast on-screen motion clearly and smoothly with less motion blur, judder and ghosting. The fast response time provides a steady visual, allowing players to experience their games at the high level. -
Built-in stereo speakers and multiple ports
The powerful, built-in 5 W stereo speakers deliver full, rich sound for watching movies or playing games. The Samsung CF591 monitor comes with multiple ports including HDMI and DisplayPort to provide multiple options for connectivity. Enhance your computing experience by easily connecting to your PCs, game consoles, additional monitors and more. -
Eye Saver mode
Eye Saver mode optimizes your viewing comfort by reducing blue light emissions and flickers at the touch of a button. Read documents, play games, watch movies and edit photos for long periods of time, and experience a comfortable and pleasing view, without worrying about eye strain or fatigue. -
Brilliant picture quality
- Samsung C27F591FDU - CF591 Series - LED monitor - curved - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class B
- Energy Consumption per Year
- 54 kWh
- Power Consumption (On mode)
- 37 W
- Curved Screen
- Adaptive-Sync Technology
- AMD FreeSync
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.3113 mm
- Brightness
- 250 cd/m²
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA, DisplayPort
- Tilt
- White silver
- 61.42 cm x 27.04 cm x 45.73 cm
- 4.4 kg
- DDC-2B, ISO 9241-307
- Display Type
- Energy Class
- Class B
- 54 kWh
- Diagonal Size
- 27"
- Curved Screen
- Yes (1800R)
- AMD FreeSync
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.3113 mm
- Brightness
- 250 cd/m²
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- MagicBright, game mode, Eco Saving, Mega Infinity Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Mercury free, Eye Saver Mode, Active Crystal Color
- White silver
- 61.42 cm x 27.04 cm x 45.73 cm - with stand
- 4.4 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 5 Watt
- VGA , HDMI , DisplayPort , Audio line-in , Headphones
Mechanical
- Tilt
- Cables Included
- 1 x HDMI cable
- 37 W
- Power Consumption Stand by
- 0.3 Watt
- 0.3 Watt
- OS Required
- Apple MacOS, Windows 10
- Dimensions & Weight Details
- With stand - width: 61.42 cm - depth: 27.04 cm - height: 45.73 cm - weight: 4.4 kg , Without stand - width: 61.42 cm - depth: 14.29 cm - height: 36.29 cm
