Give your devices the powerful charging support they deserve. The Wall Charger for Super Fast Charging (25W) provides Super Fast Charging at up to 25W for capable devices This Wall Charger will not only quickly power the fastest charging devices, but it’ll also play well with other models too. So for standard PD 3.0 compatible devices you'll get a max 25W charge, while others charge at speeds they can handle
*Plug only, compatible with Type C to Type C cables
- Samsung GP-PTU020SOA power adapter - 24 pin USB-C - 25 Watt
- Product Type
- Power adapter
- Output Connector Type
- 24 pin USB-C
- Voltage Required
- AC 100-240 V
- Max Electric Current
- 2.77 A
- Fast Charge Technology
- Fast Charge
- Power Provided
- 25 Watt
- Product Type
- Power adapter
- Voltage Required
- AC 100-240 V
- Input Connectors
- Power
- Input Connectors Qty
- 1
- Output connectors
- 24 pin USB-C
- Power Provided
- 25 Watt
- 2.77 A
- Fast Charge
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
H3V9 048688 Condition: Damaged stock - Item is new but has packaging damage |
£5.96 |
Legend
- This part of the stock item is present and in good condition
- This part of the stock item is not present or functional
- This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
- This part of the stock item is not applicable e.g. it might not include accessories or software as standard
- This item has not been tested.
