Give your devices the powerful charging support they deserve. The Wall Charger for Super Fast Charging (25W) provides Super Fast Charging at up to 25W for capable devices This Wall Charger will not only quickly power the fastest charging devices, but it’ll also play well with other models too. So for standard PD 3.0 compatible devices you'll get a max 25W charge, while others charge at speeds they can handle
*Plug only, compatible with Type C to Type C cables
- Samsung GP-PTU020SOA power adapter - 24 pin USB-C - 25 Watt
- Product Type
- Power adapter
- Output Connector Type
- 24 pin USB-C
- Voltage Required
- AC 100-240 V
- Max Electric Current
- 2.77 A
- Fast Charge Technology
- Fast Charge
- Power Provided
- 25 Watt
- Product Type
- Power adapter
- Voltage Required
- AC 100-240 V
- Input Connectors
- Power
- Input Connectors Qty
- 1
- Output connectors
- 24 pin USB-C
- Power Provided
- 25 Watt
- 2.77 A
- Fast Charge
